Bookshelfs or Dipoles?
CaptainMurphy
This is going to be the next purchase in my HT and was wondering what feedback you guys have is it better to just go with the dipoles or get bookshelfs i'm going to eventullay have a 7.1 system with floorstands as fronts and rears just wanted to know if it was better to go with dipoles or bookshelfs for the sides.
Reciever: Onkyo TXNR801
Mains: Polk RTI10's
Center: Polk CSI5
Sub: Polk PSW505, Polk PSW10
CD: Onkyo DXC390
DVD: Samsung DVDHD841
HDTV: Panasonic 44" LCD
XBOX 360
Mains: Polk RTI10's
Center: Polk CSI5
CD: Onkyo DXC390
XBOX 360
Post edited by CaptainMurphy on
Dipoles for the sides , bookshelves for the rear.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
I hung a pair of Rti6's up in the corners as rears and pointed them towards each other and you will be astonished at how real that will make the rear surround field appear. Do not waste your cash on rear floor standers. They just wont sound as good unless there up high. I know it is hard to believe but you have to try it to understand it.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
Far more common to have rears at ear level if the room allows it.
CaptM.,
Agree with wingnut on dipoles as being the better choice for the sides.
Part of my "what the room allows" comment above is how far the rears are from your listening position. If a few feet or more, then direct radiators are a good option; if less, then diploes should be considered there as well.
Whatever you choose, if you have placement options, use stepladders to try different locations.More later,
Tour...
Vox Copuli
5.1- Dipoles for the sides. Monopoles for the rears.
7.1- Bipoles for the sides and rears: movies or music. -
How many speakers do you have in your 5.1 rig?
More later,
Tour...
Vox Copuli
