3805 Cap Size
speakergeek
speakergeek Posts: 555
edited December 2005 in Electronics
Any of you guys know how large(microfarads) the filter caps are in the Denon AVR-3805? Just curious.
Cheers
Post edited by speakergeek on
    heiney9 Posts: 25,409
    Cheers
    Take the top off and have a look see. I know...a pain in the **** if it's in a rack. :D
  • speakergeek
    I personally don't have one to look at, but I was hoping one of you might know. Been thinking about acquiring either a 3805 or maybe an Outlaw 1070.
  • speakergeek
    No takers on this one huh? I thought for sure there would be someone who knows.
    F1nut Posts: 51,699
    Ask Denon.
  • speakergeek
    F1nut wrote:
    Ask Denon.
    Now that's just brilliant! :o
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    yeah, but good luck getting a response...
  • speakergeek
    Email sent. We'll see if they say anything.
    Try joining the DIY audio forum DIYAUDIO.COM and see if anyone there might know. Call Denon or perhaps search on-line for a manual. There are lots of 3805's on this forum but I guess know one can answer your question.
    While cap size is an indicator of power reserves in a receiver it really won't make that much difference in a receiver. There are many other areas that are more important than cap size. But, I understand you being curious about it.
  • speakergeek
    My guess is around 15-18000 uF apiece, but they look like they may be just a tad larger than that. Just something I'd like to know. I'll find an answer.
  • speakergeek
    Denon did get back to me. The caps are rated at 15000 uF 71V. Not to shabby, but the 1070 doubles that I think (4x15000) for a more robust reserve.
  • MrNightly
    MrNightly Posts: 3,370
    Not to side track this thread... but i just got my 3805 from Opus, and Boy oh boy... its a beauty!!! Its my first ever AVR and i couldn't be happier!!! Just got the DVD and TV hooked up, and popped in the matrix. Sounds great!! (Even if i only have RTi8's so far for speakers!!! Ha)
    This is fun.
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
  • speakergeek
    After reading around about the Pioneer VSX-1015TX and discovering the excellent power supply (rivalling the 3805) it has, I decided to go for it instead. It has the same size caps as the 3805 and a pretty hefty transformer to boot. Not bad for 1/2 the price of the 3805. The Mosfet amp sounds warm with my RT7s, CSi30 and surrounds.
    Cheers!
