Need center for SDA SRS & 1C
Jose_L
Hello everyone,
I'm looking for suggestions on what to do w/ my system.. I have a pair of SDA SRS 2.0's (mains) and
a pair of SDA 1C's (rears) and a CS350 center.
My living room is 20'x22'x10', and I'll be getting a SVS PB12-Plus/2 sub soon..
The biggest problem I have is my center seems small compared to all my other speakers.
BTW I have a AVM20v2 w/ 3 carver amps..
I thought of building a center w/ replacement tweeters & mid/woofer's from Polk, but the tech support guy said it was better to get a CSi5 center..
What can I do ? What the best center available ?
Thank you for your help..
Regards,
Jose
Regards,
Jose
Original SDA owner 1988 - 2006
Tyler Linbrook owner 2006
Post edited by Jose_L on
Welcome, Jose.
If you are still running the original SL2000 tweeters, then the CS350LS style tweeter is going to be a better match. Any single center is going to seem undersized from an appearance standpoint, but sonics are all that matter.
That said, I opted for twin CS400's, one above and one below my CRT. If you can do something similar, you might seek out a second CS350...More later,
Tour...
Vox Copuli
or maybe.. get yourself a pair of SDA CRS's. and run them as your centers.. but without the SDA cable..PolkFest 2012, who's going>?
My input is in your other thread.
If I change all my tweeters to the RD0194-1 then which center would match ?
Is it better to change all my tweeters, I do find my polks seem to be a bit bright..
Regards,
JoseOriginal SDA owner 1988 - 2006
