i got a problem
fortytha12gauge
fortytha12gauge Posts: 47
edited December 2005 in Car Audio & Electronics
i have 2 amps hooked up how do i wire the remote wire? both of them together wont work.
Shadow Inc records
Post edited by fortytha12gauge on
  • skydeaner
    skydeaner Posts: 187
    You might need to run a relay, check out www.the12volt.com you should be able to find an answer there
    Fiberglass reminds me of peanut brittle, only fiberglass tastes better!
  • exalted512
    exalted512 Posts: 10,735
    just split it somewhere, you dont need a relay.
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    Yeah, the remote lead from a head unit will have plenty of juice to turn on a pair of amps. Jsut split it to the two and youll be set.
