Impedance
Warning ... NOVICE Post
I am reading web postings on speaker impedance and trying to understand the issues that I will be facing soon. I am in the process of finishing the basement and have decided to purchase the LC265i In-Wall speakers for my front L/R. Thinking about the LC265i for the center and LC80i for the rear L/R. Since this is new construction I wanted to put in-wall speakers in while I had the chance rather then tearing up the walls later.
I would like to use my current Yamaha HTR-5280 AV Receiver to power them. Here are some specs on the receiver. There is a impedance selector switch that I can change according on the impedance of the speakers in the system. Thus it can handle the following:
Main - 4 ohms or higher
Center - 6 Ohms or higher
Rear - 6 Ohms or higher
Thus the receiver should be able to driver the front LC265i (4 Ohms), but will I damage the speaker or receiver by trying the drive the center and rear. If I us the LC265i for center at 4 Ohms the receiver said 6 Ohms or higher. Same with the rear. The LC80i are rated at 4 Ohms but the receiver said 6 Ohms or higher.
I would be happy to buy amplifier(s) early next summer once everything is set up (if I still have money). I am just curious if I will cause any damage or just not get the most out of the speakers based on the specs.
Post edited by cewolcott on
As long as you have good ventilation around the receiver and are not playing at really high levels you should be fine. However I would recommend a power amp to get the most out of them. You could then just use the Yamaha as a Preamp/Processor.
Enjoy the new system, and welcome to the Club!
If you have more questions don't hesitate to ask.
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Basically, give it a shot and if your yamaha shuts down at the levels that you want to reach, you'll know that you need a bigger amp. Mine was crapping out trying to drive my LSi's so I had to add a power amp (which greatly improved the sound, BTW)Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
This is probably a dum question, but here it goes. I have read about how the top end of the LSi speakers are cleaner than the RTi series, say a LSi15 to a RTi10. Can you mount a LCi tweater in a RTi, or the fact the LSi is a 4 ohm to a RTi 8 ohm get in the way?
Yamaha 2400 receiver
Denon 2900 DVD/ universal
Anthem 20 and 30
Monster 3500 power
RTi 10 fronts
CSi5 center
RTi6 surrounds and backs
HSU VTF2-MK2 -
Actually there are many things to get in the way. Speakers are a fine art. Everything about them is precisely matched to everything else. Crossover, drivers, and cabinets are all specifically designed to work with one another.
I think I'll stop there for now. One could go on for days about the details. :rolleyes:HT
2 CH
In other words don't mess with something you don't understand!
