Polk XM XRt 12 Connections
koiman
Is it possible to use both the Digital and analog cables on two seperate amps at the same time without hurting the unit.
Thanks,
Thanks,
Post edited by koiman on
yes, but you need something with a DAC to convert the signal
My main concern was that it was possible to use both outputs at the same time. I'm not interested in having both outputs Digital. I wanted to Have output to another room.
