Speaker wiring 101 (polarity?)
peekobi
peekobi Posts: 58
I know that the positive (+) and negative (-) speaker wires should always be consistent to keeping the speakers in phase. My question: is there an easy way to identify the + from the - on the wire? Or do you have to trace them from receiver all the way to the speakers.
I'm using heavy monster wire up front for my fronts & center, while my backs & rears are 16 gage Radio Shack wire. I can't tell in either case which is which. (+ or -) Is this really a big deal?
Reciever Onkyo TX-SR708
Center - polkaudio CS245I
Mains -- polkaudio RT600I's
Sides -- polkaudio RT35's
Rears -- polkaudio RT25I's
Sub ---- polkaudio PSW-350
TV: Panasonic TC-P50GT30 HDTV
Blu-Ray Player Panasonic DMP-BDT215
Common sense ain't that common!:loneranger:
Post edited by peekobi on
  • McLoki
    McLoki Posts: 5,231
    edited December 2005
    I am not sure on your wire, but most speaker wire has writing of some kind only on one side of the speaker wire. Just always plug the side with writing into the red (or black if you preferr) connection and they will stay straight.
    Yes, it is worth the minimal time it will take to ensure that the speakers are running with the correct polarity.
    Michael
  • peekobi
    peekobi Posts: 58
    Thanks. 6 out of 7 were correct. There is writing on some and + and -'s on the others.
    Now I'm working on the Subwoofer which is a digital LFE in. I've been reading that this is NOT the way to wire this.
