My Jolida and Rti 10's are to bright.
PRC
PRC Posts: 58
edited December 2005 in 2 Channel Audio
Hello,
I’ve been listening for the last couple months to my new system. I really like the tube sound. In the distant future I would like to go all tube.
However, I need some help with fine-tuning. What I’m finding is that the clarity (IMO) is very good. Sound stage and depth are pretty good for a hybrid. I’m hearing a lot of new sounds. The negative is that the system seems a little to bight. I bi-wired the speakers and used the Kimber Kable, which is designed for clarity. I don’t want to change components so I wanted to know if anyone has some ideas on how to help with the brightness. New tubes came to mind, but I don’t know what brand would soften the sound. Thanks for the input.
Patrick
Jolida JD1501RC -Telefunken tubes
Jolida JD9 Phono Stage
Rega P2- Dynavector 10x4 Mk.II Cartridge
Music Hall mmf cd-25
Canton Ergo 900 DC
Polk PSW404
Kimber "Timbre" IC's
Tributaries "SP4BW" - bi-wired
Post edited by PRC on
  • Ricardo
    Ricardo Posts: 10,636
    Unfortunately I think your problem is the speakers....the RTi line is bright, which is great for Home Theater, but not so good for music.....you might be able to do something changing tubes, but IMO if you want to get rid of that brightness and if you use those speakers only for 2 channel music....then you should try trading them for something else....
    SOPA
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    If the Jolida has those stock chinese tubes you should change them out that which should help some. The usual suspects are Amperex, Mullard, Telefunken, on down.
    There was once a time when you could not tell anyone but you could turn down the treble a bit to see how you like it. This heresy of audio however has pretty much been eliminated on gear by removing the tone control.
    As suggested your speakers are considered to be detailed, made with focus on HT, you may find the lsi7 most enjoyable, using them for you music.
    RT1
  • Early B.
    Early B. Posts: 7,900
    I agree with HTrookie. Changing tubes will only provide a slight change.
    If you're using a subwoofer, you can substitute your Rti10's for a nice pair of bookshelf speakers -- maybe the Lsi7's or Lsi9's if you want to stay with the Polk brand. Otherwise, there are tons of options out there, many of which cost less than what you could sell your RTi10's for.
    "God grooves with tubes."
  • ND13
    ND13 Posts: 7,601
    I don't know, but if you were to throw some of those "Bucket O Mud" Mullards in their, they might tone the RTi 10s down a bit. :D
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • steveinaz
    steveinaz Posts: 19,538
    How much toe-in are you using on the RTi's? Try facing them more forward or reduce toe-in to a 1/2"
  • Mike Reeter
    Mike Reeter Posts: 4,315
    I bought a pair of RTi12's to pull double duty,HT and 2-channel...Those tweeters are just too bright for music listening.
    I would try to find something different,or start putting together a dedicated 2-channel rig...you can find used SDA's for less than a pair of used LSi 9's...
  • keith allen
    keith allen Posts: 734
    I have RTi8's,and love them,other than the harsh tweets...how bout an upgrade from Polk,Id be happy to plunk down a little dough for something a little warmer,then I'd have perfect speakers ;)
  • janmike
    janmike Posts: 6,146
    Enlighten me. What is toe-in?
    Michael ;)
    NORTH of 60°
  • amulford
    amulford Posts: 5,020
    when you toe in, you aim the speakers towards you at the "sweet" (listening) spot instead of just straight forward.
  • janmike
    Thanks, I do that, just didn't know the technical term.
    Michael ;)
    NORTH of 60°
  • Mike Reeter
    Now,that is a good idea!!!
  • cmy330go
    cmy330go Posts: 2,341
    What is your room like? Carpet or Hardwood? Drapes or Shades? etc...
    If you have a lot of hard flat surfaces in the room you might try some soft treatments. I agree that the RTi tweeter is a little aggresive, but I have found that in the right room they can be quite pleasing with music.
    Dave
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • danger boy
    danger boy Posts: 15,722
    slightly toe them in.. not like 20 degrees or anything. most speakers only need a slight toe in.. play around with that. although it's doubtful that will help with your brightness problem.
    You may want to sell them and go with some model of LSi instead.. the LSi's i've heard are more true and not so bright with a different tweeter.
    PolkFest 2012, who's going>?
  • organ
    organ Posts: 4,969
    Getting them set up right should help if they're not properly placed at the moment. Tube rolling would be next if placement/toe-in, etc doesn't solve the problem.
    What you should look for is a tube with a very laid back presentation and with a lot less high frequency output. The only one I can think of is the JJ ECC83s(same as 12AX7). You're using 12AX7, right?
    Maurice
  • McLoki
    McLoki Posts: 5,231
    There is a set of SDA 3.1tl's for sale in eureka for about $600. I bet you could get them for closer to $500 though. I don't know what your speakers would sell for, but it may not be that expensive a change and for two channel listening, I bet they would be a pretty significant upgrade....
    Just a thought.
    Michael
  • PRC
    PRC Posts: 58
    Thanks for the input. Couple things: I toed in the speakers a fuzz. To be honest, I like th 10's. They are a little bright, but I ike the crispness and clairity. I am resisting replacing them because they are new and I paid a reasonable price for them. I did however listen to a comprable pair of Canton's. The Canton's were a little warmer but not mutch. So....I did a couple easy things that have helped already. I replaced the stock power cord with a Audio Magic cable. I also switched the CD interconnect Kimber Kable "Timbre" to a Cardas "MicroTwin". The Cardas is less forward and tones down the highs a minor amount. Im going to listen for a while and see. Thanks again for the responses. Alos, ORGAN - I know the tubes are Telefunken, but I'm not sure the exact #.
    Patrick
    Canton Ergo 900 DC
    Polk PSW404
    F1nut Posts: 50,722
    anonymouse wrote:
    I drive mine with a Rotel 980BX, and it is night and day between this and the Sony ES receiver I was using before. Your tube amp may just not have enough juice/damping to settle the 10's. A couple of things you may want to try - swap out your high end speaker cable for some garden variety (e.g. RS or Monster) 12AWG wire(short runs). Use a single run, but remove the stock gold jumpers and replace them with a small length of the same wire. I noticed that when the speakers are driven properly, the midrange really clears up. When this happens, the highs are not fatiguing and the bass seems more forward, even though I suspect thats an auditory illusion.
    I'm sure going from a receiver to a separate amp was an improvement, but the "juice" difference between the SS Rotel (120wpc) and the hybrid integrated Jolida (100wpc) is nothing, besides the damping factor has not to do with a bright tweeter.
    I don't get your idea of downgrading the speaker cable, but I do agree about replacing the stock jumpers.
    When we demoed these at Polk HQ on some very decent gear, all ten of us said the same thing, too effing bright for music, good for HT.
  • cmy330go
    I'm with F1 on this one (even though he busted my balls on the RatShack wire ;) ). I wasn't at polkfest, but I have heard the RTi's on a variety of systems. Multiple receivers, my Parasound Halo gear, and also on tubes (55w/ch KT88s). In all cases the RTis were just too bright for my taste.
    To each his own. :)
    HT
    2 CH
    F1nut Posts: 50,722
    cmy330go wrote:
    (even though he busted my balls on the RatShack wire)
    It was my pleasure ;)
  • shellrob1
    shellrob1 Posts: 1
    I have had the same problem with my Rti-10's. I fixed the problem by removing the tweeter and installing a 25 Watt, 3.9 Ohm resister inline on the positive side. This toned down the tweeters and now the sound is bright and balanced. If you do the same, I feel that you will be very please. Good Luck, Rob.
    PRC wrote:
    Hello,
    Patrick
  • aaharvel
    aaharvel Posts: 4,489
    i miss the Trilam.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
