Dynaco St-70
Doug J Keaton
Hi All. I'm new to the forum.
I've had a pair of rt1000's for a couple of years and now I want to buy a Dynaco St-70. For some reason I decided to get obsessed with tube equipment and that's the one I want/can afford.
Will this amp be a good match for the speakers? I'm at work now, but from what I recall they are 200 watt speakers with a sub-woofer. Is 35 watts per channel too little to power?
Also, as far as wiring goes I obviously can't use a sub-woofer connection from the amp so do I just go with a normal hook up for the speakers?
Post edited by Doug J Keaton on
Depends on how loud you like your music. 35 watts is no push-over, just be careful about pushing the amp too hard.
Let some of the experts with this particular speaker/knowledge of this amp chime in though.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
With the 1000's powered sub handling the load below 80Hz, I think a ST-70 is a good place to start, if you're set on going tube amp.
Alternative to consider would be a tube pre-amp with a SS amp behind it.
Welcome to the Club...More later,
Tour...
Vox Copuli
I'd opt for the tube pre/SS amp option as well
Hi Doug,
Welcome to the forum.
You will be amazed by the RT/Dyna combo. I used to have a pair of RT800i that I ran with my ST70 and the sound was just amazing. I would take that system over my LSi/NAD combo any day.
If you're not planning to annoy your neighbors, the Dyna should provide enough power.
Make sure the amp have been tested by a technician and is working right. Dynacos are old and a lot of ST70 need plenty of TLC. If you decide to get the Dynaco, forget the EL34 output tubes. Get KT66 instead.
Maurice -
organ wrote:If you decide to get the Dynaco, forget the EL34 output tubes. Get KT66 instead.
Won't he have to do the triode operation mods to run KT66? -
Hi Mike,
No need to do the triode mod for KT66. My 66 are running in ultralinear.
Actually, I did the triode mod last week to see how they perform. Went back to ultralinear in two days. -
I went ahead and bought the Dynaco. I will also be buying a Scott 130 preamp to match. I hope it all works out.
As far as the sub-woofer goes do I just run a normal old set up? Before I had a sub-woofer out channel - that is obviously not the case with the Dynaco. -
Kick ****! Congrats on your purchase. The ST-70 is really something special. I love mine very much and will probably be my last amp.
A few questions... What tubes did you get with it? If it's the original "Dynaco" labeled tubes or anything that says Mullard, take them out and put them in a safe place and replace with current production. Those old Mullard tubes are worth a lot of $$$.
Do you have a multimeter? You're going to need one to bias the amp.
Is the amp stock or modded?
Here's a great site with a ton of info that will come in handy to all ST-70 owners www.dynaco-doctor.com
I've done a lot of work on my amp. Feel free to PM me if you have any questions.
Maurice -
I think Maurice is more excited than Doug...
Congrats, Doug. Assuming your Sub has a built in cross-over, just feed it via the speaker level inputs, then carry on from it to your mains.More later,
Tour...
Vox Copuli
It's the audio research modification and in absolutely in great shape. It's the older model with the brown shell - so I think it has the cloth lead transformers I read so much about. I'm having the inputs replaced with some gold plated stuff (It was recommended), but everything else should be about good to go.
The amp is at a repair shop now being looked over. Is there anything I should ask them to fix or update in particular?
I don't know about the tubes, but I'll check that out for sure.
Any opinions on the Scott 130 preamp?
