denon 3805
moraks
can the denon 3805 provide audio in a second room without another amplifier while being used as a 5.1 audiovideo function in the main room :cool:
Post edited by moraks on
Yes; you can use the "Zone 2" speakers output and select sources independently for each zone._________________________________________________
Yes, the 3805 can do this for you.
Edit: Researching and typing at the same time often leads to the same answer twice.Tschüss
Zach -
thanks, follow up question can the source in the second room be the tuner on the reciever or does it have to be an indeoendent source like a cd player or some other independent source? thanks again for the prompt response.
moraks wrote:thanks, follow up question can the source in the second room be the tuner on the reciever or does it have to be an indeoendent source like a cd player or some other independent source? thanks again for the prompt response.
Not sure about that one...but here you can download the manual:
http://usa.denon.com/ProductDetails/356.asp_________________________________________________
Yes, it can be the tuner. The second zone is utilized when you assign the rear surround speakers to second zone, rather than rear surround speakers for 7.1 usage. The only caveat is that the second zone can only run on analog sources, like a CD player, tuner, analog inputs for DVD, etc.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
From what I know, the source for the Zone 2 must be analog. So no digital inputs.
Edit: Ok, I'm not sure of that for the 3805, but I know its true for the 3803 and my 4802.
