Need help???
I have a pair of RTi38s. The crossover has come undone from the binding posts as you can see in the pictures attached. Wires from crossover to the woofer and tweeter are still attached. Anyone havs suggestions on how to fix? What should I use to re-attach?
I guess the pics are too large to attach. I will try later with the pics.
Ok...pics are loaded. You can see where the binding posts have separated from the crossover. The first is the back (or inside the speaker) of the binding posts. If I touch them together just right, the speaker works. Can this be fixed or do I need a new post/crossover piece??
Post edited by mknutt on
Can someone tell me how to reduce the size of the pics?
