DEFINITIVE subwoofer
doggie750
doggie750 Posts: 1,160
Hello Polkbrothers,
I went to magnolia HIFI last night and I came across with this HighEND SUB...
"DEFINITIVE"............Got any 2 cents for meh?
http://www.definitivetech.com/loudspeakers/subwoofers/subwoofers.html
The ProSub 100TL — The ProSub 100TL with a 10" driver, incorporates all the features and technology of the ProSub 200TL.
ProSub 100TL Specifications:
Dimensions: 11-1/4" W x 17" D x 14-1/4" H
Frequency Response: 19 — 150 Hz
Driver Complement: One high-definition 10" driver with polymer cone
Built-in Amplifier: 250 watts RMS
Low Pass Crossover: 24 dB/octave continuously adjustable variable (40 —150 Hz), plus direct LFE input option
High Pass Crossover: 6 dB/octave at 80Hz
Auto On/Off: Signal sensing.
Finish: Black ash or white laminate
Weight: 32 lbs.
Retail: $449 ea. SALE PRICE: $339
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • gregure
    gregure Posts: 871
    edited December 2005
    Well, I used to work at Magnolia, and can tell you that the Definitives are not very good compared to Magnolia's other lines, especially the Prosub series. They are boomy and not very good for music. Additionally, Def Tech publishes only overall frequency responses, which means that 19Hz is not a very usable extension, perhaps 19Hz at -10 to -20 dB. Look for ratings that say 19Hz at +/- 3dB and you'll be seeing realistic numbers.
    Honestly, for a great sub with good extension (25Hz at -3dB, believe me, better than the Prosub 100) look at the Dynamo from Martin Logan. A great sub, small, compact, plenty of power and punch for movies, but a real articulate and quick quality for music. At $600, it's not cheap, but the best entry-level sub available from any line, let alone for what Magnolia has to offer. If you can spring for it, the Grotto from Martin Logan is the next step up, and a bit better at giving you that really low LFE rumble.
    Def Tech subs are ok, and the Supercube series is decent if your primary use is Home Theater and rap music. Anything else and it muddies it all up with boomy bass. You get more boom, at the expense of actually being able to discern the bass line notes, which Martin Logan does best in my opinion.
    If you listen to music even 20% if the time, don't get a Def Tech sub.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • gregure
    gregure Posts: 871
    Wait, you have an SVS PB12/2+. Why are you looking at Def Tech?
    Current System:
    B&K AVR 507
  • McLoki
    McLoki Posts: 5,231
    If any salesman uses the term HighEnd and quotes a normal price of under $500 for a sub, he is lying. I am not saying that there are not decent subs available for that price, but I would question calling any of them high end.
    I would say (in my opinion) that REAL subs (that can be called high end without crossing your fingers or your nose starting to grow) start in the $600 range and go up to the "you spent WHAT on a sub?" range from there.
    Just my opinion,
    Michael
    VR3 Posts: 29,537
    DT subs are BOOOOOOOOOOOOOOOOOO
    And I am the biggest, loyalist DT fan you will EVER see.
  • doggie750
    SVS is the MONSTER........
    Christmas is around the corner so I am up for shopping....
    THanks for the inputs, I appreciate it very much.......My budget is around $300 more or less. Got any ideas?
    He likes to listen to Jazz....and watch movies...........Please advise
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • BIZILL
    BIZILL Posts: 5,432
    good thing i found this polkaudio forum. i was on the verge of purchasing a def tech supercube reference. ended up with the svs after reading through reviews here.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • WilliamM2
    WilliamM2 Posts: 4,808
    This is well under $300, and free shipping to boot:
    http://www.vanns.com/shop/servlet/item/features/549709556
    This sub really impressed me for the price, so much so that I got an Energy s12.3, which is basically Energy's 12" inch version of the same sub. Energy and Mirage use the same drivers, amps, and cabinet dimensions (same manufacturer).
    The color of the Mirage is a dark charcoal grey, not the brown that is appears on the site above.
  • gregure
    gregure Posts: 871
    Unfortunately, uless you find something great used, anything under $500 is going to be ****. Especially for jazz, which requires quick, musical subs to sound good at all. If your friend doesn't care, and has no ear for what a good sound system is, you should be fine spending only $300. Honestly, you should buy him something else and let him save up for a better sub himself.
    Current System:
    B&K AVR 507
  • doggie750
    Thank you for the INPUTs polkBrothers......
    Due to the high respect to all of you, DT sub is out of my list. WILLIAMM2, thank you for the link....I am looking at it right now.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
