Buying a new sub..
tecmo04
I have a freind that works at bb. hes allowing me to use his discount if i wnat to buy the Klipsh 12" sub. curious if people have tried it, what they think? i dont know if i can pass up the price...
linky
id ask the klipsh forum but i know the answer id get so im looking for an impartial review. i havent had a chance to hear it yet but plan to this week...
i am currently running a velodyne cht 12
any help would be great, thanks!
Rookie trying to become a pro
linky
Post edited by tecmo04 on
Looks like a lateral move. Your Velo ought to sound just as good, if not better.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Those klipsh subs are mostly all rumble and no "real" base. I almost bought one about a year ago but they are not crisp or clear. Please do not buy one. I dont know if I would even use one if I got it for half price.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
Actually the Sub 10 and 12 are a big improvement from the KSW series. I was impressed with the Sub 10 in my room for a couple of weeks. That being said, I think it's a lateral move too.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
if i did buy it i would run both, not replace the velo. am i wasting money if i buy it?
i guess my real question is how much benifet will i gain from running a second sub? -
Adding a 2nd Sub will give you more headroom, due to less strain on the amps. It will also give you up to a 6db gain in output, if co-located. If not, then placement and cancellation issues are problematic. Once setup correctly, you'll have an output bonus and should get a more even bass response. Could be tricky, could be fairly easy.
I co-located a 2nd XSub this weekend, probably picked up a couple of hz in extention and the output gain. Very nice.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
