Monstercable Powercenter HTS3500
*waits for Russ' obligatory "eff monster" post*
That's a nice price on what sure looks to be a beefy power center!Ludicrous gibs! -
Very Nice indeed, I haven't even seen it that low on the used (ebay) market.
nadams wrote:*waits for Russ' obligatory "eff monster" post*
Why wait?!! Here you go:
http://www.madmartian.com/legal/
http://www.monstervintage.com/
http://durangoherald.com/asp-bin/article_generation.asp?article_type=news&article_path=/news/04/news041223_2.htm
http://ttabvue.uspto.gov/ttabvue/v?qt=adv&qs=monster%20cable%20products&page=1 -
Wow, that's super cheap. They must be trying to clear them out. I predict they'll sell out in a hurry. Nobody else sells this for less than $250.
I was looking for a good power conditioner, is this any good?
I've got the mkII version and it works really well. It has tripped about 5 or 6 times during the last 2 years, during heavy storms.
This is probably a dumb question, but whats the difference between a power conditioner and a surge protector?Fronts: RTi150's
Surrounds: FXi50's
Center: CSi40
Rears: RTi38's
Sub: PSW450
AVR: H/K 525
DVD1: Samsung HD-831
DVD2: Pioneer 563A
HDTV: Sony Grand WEGA KF50XBR800
Amp: Adcom 5503 -
I'm about to order one of these. Pretty good deal.
A surge protector takes the hit in the event of a large power surge (lightning and the like), sacrificing itself to protect your equipment. Beyond that, it does nothing.
A power conditioner is working all the time to level out any dirty power that you might have in your house. Let's say you're listening to your rig, and the furnace kicks on. That may cause a "snap" in your audio, from the furnace sucking down a large initial amount of power. A power conditioner would smooth that out and eliminate the snap. Those types of thing...Ludicrous gibs! -
jruff98 wrote:This is probably a dumb question, but whats the difference between a power conditioner and a surge protector?
Power Conditioners are supposed to provide protection in surges (spikes) from the outlet. They are also supposed to provide some EMI protection, as well as keeping the power to the components consistant. In my experience though the monster products do not keep the voltage constant, at least it isn't constant on the analog/digital meters. I have seen it vary from 119 to about 116 volts.
Surge Protectors simply protect the component by shunting any power spikes to the ground wire....
I don't own the AVS2000 that monster has, but I can tell you from seeing them on display (take it for what its worth), that they add or subtract voltage variations to keep the power close to 120 volts.
I guess to have the best of both worlds Monster would like you to use both of their products, by plugging the "conditioner" into their AVS2000 stabilizer, and then theoretically you will get a constant "conditioned" 120 volts to your gear..
scott
Edit: I plan on getting the AVS 2000 as soon as it comes down to a "reasonable" price point. And plugging in my HTS5000 and HTS5001 to it. -
I think I am currently using a Monster PB1100. I'm planning to move in a few weeks to an older building, and I'm concerned about protecting my equipment. If I understand correctly, it sounds like the power conditioner would be more of a complent to my current powerbar than it would a replacement/upgrade.Fronts: RTi150's
Surrounds: FXi50's
Center: CSi40
Rears: RTi38's
Sub: PSW450
AVR: H/K 525
DVD2: Pioneer 563A
Amp: Adcom 5503 -
Look at the Belkin products that do the same thing.
I think you would be OK with your PB1100, as it also offers protection to your equipment...
Anyone else getting one?
PolkThug wrote:Look at the Belkin products that do the same thing.
model # ?
what about the other one..? forgot the brand BTS..?
"b" somethin somethin
That`s it balanced Tech...!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
I got one! Can't beat the price. Like anything, you can spend a lot of money on power conditioners, surge protectors, etc. I plan to install a whole house surge protector at the electric service box next Spring, cost about $700. For the time being this is a great deal.Carl
I'm currently thinking about getting one. I'll let you guys know if I do.Fronts: RTi150's
Surrounds: FXi50's
Center: CSi40
Rears: RTi38's
Sub: PSW450
AVR: H/K 525
DVD2: Pioneer 563A
Amp: Adcom 5503 -
I got one, and it was at my door yesterday. I hooked it up and looks good. The voltage meter stays constant at 124 volts after I turn it on. I don't see any fluctuations at all. Is this good?
How long is the power cord on this thing?"she had the body of Venus, with arms."
Which is better?
The Monster HTS-3500?
or
The Belkin PureAV PF40?
They're both about the same price but looking at the specs - the Monster is around 5 pounds while the Belkin is around 15. Also, the PF40 has more inputs in the back and a surge protection of around 6500 while the Monster 3500 has less than 3000....
What do you guys think?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I think Monster has the specs wrong on their site. Shipping wieght is 17.5 pounds.
Anyone know if this would be an improvement over a Panamax 4300? -
I have a panamax and I like the security it provides me.
It has only tripped once so far but that may just have been the one time I saved thousands of dollars.
Great piece of mind.
I do not know about the monster product but from what I have read about the company I would not waste my money supporting them and paying for their advertising budget.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Sky
I have to agree, they do have a bloated advertising bucket and it shows in their MSRP, but at 135.00 I have to say this is a deal. I wouldn't of paid 599.00 for the 5100 either. But I cut a "deal" at the local Good Guys, (RIP, Closed down recently) for two of the 5100's for 700.00, (floor models), and that was a great deal to me...
Scott -
thehaens@cox.ne wrote:Sky
Scott
Dude that is a killer deal.
I think I paid over $700.00 for mine.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Just ordered one of these. Now I'll move the APC UPS that I had my HT equipment plugged into over to my computer system...
I too don't find Monsters practices to be too appealing, but this was a good deal. I have had prior issues with Dell on lousy CS, but once the deal comes along, it just doesn't matter.
Just ordered one. $206.57 with ground shipping. Cant go wrong on this deal. If I dont like it will hook it up on my PC. Thanks warlocks1 for the link.
GatorTheatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
I guess they don't ship for free to Canada?
can't find how long power cord is on this...anyone have a clue?"she had the body of Venus, with arms."
