SDA-SRS Quickie!
jfb4548
I know I read about this once before but I'll ask again anyway! What tap should I run my SDA-SRS from on my power amp? It seems to me they are 6 ohm so do I go down to the 4 ohm tap or up to the 8 ohm tap??
Thanks as always!
Thanks as always!
Post edited by jfb4548 on
4 ohm.
I believe the SDA-SRSs are rated at a nominal impedence of 4 ohms anyways.
Other interesting ratings in case one has forgotten:
Frequency response - 10 Hz- 26,000Hz
Crossover Frequency - 45 Hz and 2000Hz
Max output level - 125dB
Effiiciency - 93dB -
There's a couple different nom imp's quoted for the SRS's. Some state 6 ohm, my manual states 5 ohm.More later,
Tour...
Vox Copuli
What else is new with Polk and their model lines?
Lets see, original SDA-SRSs... they were made in '85, '86, '87, '88... I only have spec sheets dated '86, '87, and '88. At least the sheets I have all have them at 4 ohms and is what I was going by. Doesn't make it written in stone though as we have found sometimes. -
Tour2ma wrote:There's a couple different nom imp's quoted for the SRS's. Some state 6 ohm, my manual states 5 ohm.
Hum. My owners manual says 6 ohms. But then again when I removed my cross over to have a look it didn't look much like the ones pictured in the upgrade thread, so maybe Matthew changed things as he went along? -
Hey Bob,
Actually I meant to type 4-ohm, not 6 in my initial reply...
jfb,
6-ohm came into play when the 1.2's came along. Regardless, 4, 5, or 6-ohm, the 4-ohms taps are the ones to use.
Had I noticed your posts sooner, I'd have looked you up. I've been sitting in Parma for the past week.
EDIT: 4-ohm tap, not 6-ohm...More later,
Tour...
Vox Copuli
Tour2ma wrote:Hey Bob,
jfb,
6-ohm came into play when the 1.2's came along. Regardless, 4, 5, or 6-ohm, the 6-ohms taps are the ones to use.
Parma! Sorry we didn't hook up! I work in Downtown Cleveland...not to far from Parma. But still my owners manual says 6 Ohms! -
jfb4548 wrote:Parma! Sorry we didn't hook up! I work in Downtown Cleveland...not to far from Parma. But still my owners manual says 6 Ohms!
Now you got me thinking and that's not good! I'm going to have to dig out my owners manual when I get home and reread the specs! Either way my amps all are 2 ohm, 4 ohm or 8 ohm so the 4 ohm tap is still my best bet? -
Yup... Even for 8-ohm speakers, many folks perfer using the lowest ohm outputs their amp has...
What amp are you running?More later,
Tour...
Vox Copuli
Tour2ma wrote:Yup... Even for 8-ohm speakers, many folks perfer using the lowest ohm outputs their amp has...
Right now I'm running my vintage McIntosh MC2205 but my main amp is a MC7270. Just a bit newer and a lot more balls! -
I dug out my owners manual and it say's 5 ohms not 6! I guess my memory is really shot! :rolleyes:
Not like 5-ohm is a common impedance rating...
Back in Tejas now, but hope to be back on America's North Coast come spring...More later,
Tour...
Vox Copuli
Tour2ma wrote:Not like 5-ohm is a common impedance rating...
Your lucky to be out of here! Snow and cold are the rule of the day. Did I mention COLD?
The good to come out of all this is messing around trying various hook ups I found my IC between the pre and amp was messed up. New cables in place and no more problems man! To think I swapped every piece and some twice because of a stupid cable! :rolleyes: These dang amps tip the scales at like 80 lbs and my old back aint what it used to be! -
My manual doesn't even call it "impedance", it calls it plain old "D.C. Resistance"
5 Ohms
I'm kinda mad, cause I had the manual in a box, which for some reason I put in my truck, so it got a bit damp and got kinda moldy on me. Oh well, at least the speakers are shiny!
And it's almost their b-day. I pulled the mids, they said Nov 18, 1985. But the tweets (SL-2000's) Say Jan 2, 1986.
Currently: Live Bullet
