Help Me Decide
I have a new speaker choice to make for Christmas, and I am looking for some opinions. My choices are between subs and surrounds. My present setup is great and I love it, but you all know how this hobby is! Hear are my options:
1. Upgrade the rear surrounds from FXi3s to FXi5s. Have FXi5s on the side already.
2. Upgrade HSU-STF-2 Sub to VTF-3 MK2
or
3. Upgrade PB10-ISD sub to PB12-ISD
Looking at my current setup, which of these choices would you make? Or do you think based on the current setup, none of them will make that much of a difference?
or
Main theater: Paradigm Studio 100's v4 L/R, CC690 Center, ADP 590 x4 Surrounds. Dual Outlaw LFM-EX-1's, Yamaha Aventage RX-A1010 as Processor, Anthem PVA-7 Amp
Secondary System: Polk RTi 6 L/R, CSi3, Center, FXi3 x4 Surrounds, Def-Tech Supercube II, Pioneer Elite VSX-23 Receiver
Post edited by Nelson57 on
Hell, it's XMAS....do 'em all!!!!"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Why don't you upgrade the Polk to another Hsu sub? Do you run them both for HT or use them separately for movies and music? I don't think that upgrading the rears from Fxi3s to Fxi5s are going to make a huge difference unless there is a tambre matching issue ( I have not heard them but I am sure others here know).Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Only the sub change would be heard IMO, but I would lose 2 small mismatched subs and get one big sub if setup allows. It is so much easier to tune with 1 location. The surrounds won't be noticed at all.
All-in-all you have a nicely balanced system as it is.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thats areal nice thought ND.
I kind of thought upgrading the FXi3's to 5 wouldn't make that much of a difference, but you guys gave me something I hadn't thought about with the subs. When running a dual sub setup I guess it seems best to keep both drivers the same size. If you mix a 12" woofer, with a 10" woofer, would the 12" overshadow the 10"?
I agree Dennis, I enjoy the system as is, and use it solely for movies. I just may divert the energies towards putting together a smaller secondary system in another part of the house. Thanks for your input guys.Main theater: Paradigm Studio 100's v4 L/R, CC690 Center, ADP 590 x4 Surrounds. Dual Outlaw LFM-EX-1's, Yamaha Aventage RX-A1010 as Processor, Anthem PVA-7 Amp
Secondary System: Polk RTi 6 L/R, CSi3, Center, FXi3 x4 Surrounds, Def-Tech Supercube II, Pioneer Elite VSX-23 Receiver -
Dennis Gardner wrote:Only the sub change would be heard IMO, but I would lose 2 small mismatched subs and get one big sub if setup allows. It is so much easier to tune with 1 location. The surrounds won't be noticed at all.
+1 on Dennis' comments.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Ever tried stacking your subs?
Just a thought.
RT1 -
Couldn't stack the two subs I have now reeltrouble, but with the right combo that would be a thought. I have no problems with my current setup, just have the opportunity to pick up a new item, and was thinking which way to go.
Dennis made a lot of sense, and all of you have really helped me think this through a little further, in order to get the best bang for my buck.Main theater: Paradigm Studio 100's v4 L/R, CC690 Center, ADP 590 x4 Surrounds. Dual Outlaw LFM-EX-1's, Yamaha Aventage RX-A1010 as Processor, Anthem PVA-7 Amp
