Polk surrounds ?
VinnyP61
VinnyP61 Posts: 28
edited April 2002 in Technical/Setup
Hello
I was looking for the FX 500I surrounds to go with my 800I and 400 I am running a 5.1 setup is there a modal that replaced the 500/
Post edited by VinnyP61 on
  • rodneyat
    rodneyat Posts: 67
    edited April 2002
    The FXi50 has replaced the FX500i...There is a difference tweeter in the FXi50. A number here in the group have said that it is not quite as harsh as the one in the FX500i. For surrounds, it will probably not matter as much though. ON the other hand, you still may be able to find a deal on some FX500i's if you search around.
    Rodney
    Polk RT 800i mains, CS 400i center, FX 500i surrounds, RT 35i rear centers, Definitive Supercube II, Yamaha RX-V3800, Samsung PN58C8000
