SVS PB2+(loosing a lot of bass) & BFD for tuning
doggie750
Hello POLKs,
Got a delimma here, is this needed or what? After moving 2houses within a year my SVS settings are all screwed up. SO I've been researching online and a POLKbrother sent this to me. Please advise.
Also, my HT room is actually 2 rooms in one---> Livingroom/ Den (suppose to be a office room but I stood FIRM against my wife to MAKE it a HT room).
So my HT room is divided with a French Patio door, my TV and main speakers are located to the next room (Den/office room) across from my sitting area(Living room) where my rear, side and SVS pb2+ are located.
NOTE: My SVS is placed on the left side and the bouncing wall (corner wall) has ONLY 4ft wide on both sides, basically my SVS is out on the open and I am loosing A lot of BASS, Feedback, headroom, or etc....
HELP....please
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
Hey Dog, There are those here that think they are helpful and those who don't. I bought mine here on the fm for $75 and I am quite happy with the results that I hear. It really flattened up the response curve. And it is a fun way to spend a afternoon if you are a geek like me. But with the little info given ( no room dimensions) I can't say if this would help you. I'm sure the experts will way in with their opinion but I'm not sure that it will increase your bass or headroom but should smooth things out.
Hope this helps somewhat........kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
The BFD is great, and a lot of fun, but all the BFD can do is cut peaks in response, and *maybe* do a little boosting here and there. It doesn't look like that is your problem.
You can try moving the sub around, but if there are a few openings in the room, you might need a bigger sub, or more subs.Graham -
http://bfdguide.ws/ that is the better link. anyway, is there no other place in the world you could set the sub? heck i'd at least even try turning the sub 90 degrees. i can't picture your room setup. definately does not seem any type of optimal.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
BIZILL wrote:http://bfdguide.ws/ that is the better link. anyway, is there no other place in the world you could set the sub? heck i'd at least even try turning the sub 90 degrees. i can't picture your room setup. definately does not seem any type of optimal.
how do you insert a pic???????/Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
PIC is attached!!!!!!!!!!doggie750 wrote:how do you insert a pic???????/Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
We need a frequency response chart. It will tell us the exact symptoms of your problem.
that pic locked up my computer. anyway, you'd better get to knockin down those dividing walls!!! messin' up your whole soundstage big time!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Unable to knockdown the walls due to my wife's interest. Here's my listening mode....placement.
NOTE: Plants are untouchable.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
I placed the MONSTER SVS behind my Front Speakers and BELIEVE or NOT
THIS kingKONG has AUTHORITYGodspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
