SR subs
heXtant
heXtant Posts: 56
edited December 2005 in Car Audio & Electronics
i know its probably been discussed .. but does anybody have any idea when the SR subs are coming out? ;/
System in construction.. :)
Post edited by heXtant on
  • MacLeod
    MacLeod Posts: 14,358
    Rumor is around next spring.
  • Thom
    Thom Posts: 723
    Yeah, should be March or April.
  • skydeaner
    skydeaner Posts: 187
    thats where tax returns are goin! Two sr 12" and 1 set of sr6500's and momo amps all around!
    Fiberglass reminds me of peanut brittle, only fiberglass tastes better!
  • MacLeod
    Yup, I have to somehow figure out how to hide my tax return from the wife as well! ;)
  • brettw22
    brettw22 Posts: 7,623
    Up the number of 6500's and make yourself never wanna leave your car......lol
  • MacLeod
    Gawd, I need sooooo many things.
    I need tires way bad. $800
    I need a tranny service and plug change. $200
    I need some RTi6's. $380
    I need to win the lottery.
  • neomagus00
    neomagus00 Posts: 3,899
    200 dollar tires??? i had absolute top-of-the-line summer tires last summer (bfgoodrich g-force t/a kd - basically race tires with enough tread grooves to make them street-legal), and those only outed me a buck-sixty apiece!
  • MacLeod
    Yeah, do you have size 265/70/17 tires and a 6000 pound truck? If you do I betcha youd have paid $200 each!
    Even the cheap-o tires run $130. Leaning heavily to the Goodyear Fortera for $166.
  • neomagus00
    well... does 205/50YR15 and 3200 pounds count? :p
    i've actually replaced my wheels since then, and the 205/45WR17 tires on there now were $99 apiece and outperform the old ones overall :D... they're Avon Tyres, someone i took a bit of a risk on, but it's working out absolutely wonderfully so far... you may wish to look at them?
  • MacLeod
    No, I dont chince on tires. I drive too much for crappy rubber. Im back and forth from Texas once or twice a year and countless trips to Ohio. My Michelins have performed well and I would buy them again but they dont soak up the bumps quite like I want them to so Im gonna try a smoother riding tire. The Cross Terrains are $190, the Alenza is $180 and the Fortera is $166 so thats what Ill go with more than likely.
  • cam5860
    cam5860 Posts: 632
    Put you some regal sport challengers on there BF Goodrich makes them damn good riding tire for the money.
  • MacLeod
    BFG makes damn good off road tires. Great traction and bulletproof. However the 2 sets of BFG's Ive had over the years were anything but smooth riding.
  • audiobliss
    audiobliss Posts: 12,518
    Hmm. That's a lot for tires. I just got 4 Bridgestone Dueller H/T 235/75R15 for a grand total of $327. Maybe my dad's connections are playing a bigger role than I thought.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • MacLeod
    Notice the size? Its about half the size of my tires. You have to pay for the extra rubber from a 28" tire to a 33" tire.
  • audiobliss
    Mine are like 28.8". I know the extra size would contribute to the price, but there's no way the extra rubber costs that much more!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    Oh, and 265/70R17 are only 31.606".
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • brettw22
    Look how unorderly y'all are........I think the thread title was something about an SR sub and here we're talking tire measurements......I'm disgusted...... ;)
  • exalted512
    exalted512 Posts: 10,735
    tires for a 16" wheel are more expensive for tires for a 15" wheel...generally speaking
    -Cody
  • audiobliss
    Why? There's less rubber? Only reason I can think of is because it'd possibly have to have stiffer sidewalls because there's less rubber? No, that doesn't make sense.
    Why is that?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • exalted512
    Well look up tires for a 20" wheel and the same tire for a 16" wheel. If I had to guess, and im pretty sure I'm right, its because the 15" wheel is the most common sized wheel driving prices down compared to a tire for a 16" wheel because theyre used less often. Just a theory, but look at prices, if you take the same tire, but ones for a 15" wheel and the other for a 16, the 15 is usually cheaper
    -Cody
  • neomagus00
    a) they're more expensive so tire companies can make more, because they know you'll still buy the tires (aka marketing)
    b) i think cody's right, the smaller wheels have been more common in the past (no longer, though, i think, so who knows how this'll change in three years)
    c) no, you don't need stiffer sidewalls with a larger wheel... that's half the point :p
    mac - no, i did my homework, i just chose a great company that had a good reputation, but not well-known enough to have inflated prices... it was more of a risk than buying from bfgoodrich, but not by much, and i'd take on the equivalent bfg tire any day on any category (wet, dry, snow traction, treadwear, noise, etc.) and i think i'd win on most of them... lucky me :p
  • exalted512
    yea, 17s have been getting cheaper and cheaper, but 15 is still the predominant wheel size. But with all the new cars coming stock withs 17s and 20s, im sure the demand will rise enough to lower the price
    -Cody
  • fortytha12gauge
    fortytha12gauge Posts: 47
    wat u think and would u compare to jl w6
    Shadow Inc records
  • exalted512
    a bazooka bass tube
    -Cody
  • audiobliss
    ROFL...good one, Cody!!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • neomagus00
    no one really has any idea how the sr's will sound... you'll just have to wait...
  • audiobliss
    Wait...we're all Polk Audio fans...Polk always surprises us with great products...the SR6500 was amazingly great...and we have no idea how the SR subs will be? I think I've got a pretty good 'idea'!
    :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • fortytha12gauge
    how long was break in period
    Shadow Inc records
  • Toxis
    Toxis Posts: 5,116
    duz fo'tee speek da saam lang-age as us?
  • neomagus00
    no, apparently the extra letter in 'any' is too much to ask for, despite the fact that it makes sentences almost infinitely more readable... punctuation is just asking for trouble...
    and breakin on the momo subs has generally been pretty long, about 50 hours for optimum results...
