Rat Shack 18AWG Wire???
cmy330go
cmy330go Posts: 2,341
So I was in Radio Shack today picking up a PC board and saw the "solid core hook up wire" I hear so much about. My question is how long of a run can (or should) I make with this stuff? I'm am planning on trying this on my 2ch rig. I'll be running the LSi9's on my 55w/ch tube integrated. My speakers are only about 5 feet from the amp. Will I have to double it up? Or will that defeat the purpose of it being solid?
Thanks in advance for the help.
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
Post edited by cmy330go on
  • Mjr7531
    Mjr7531 Posts: 856
    edited November 2005
    According to this table, it's feasable
    http://www.roger-russell.com/wire/wire.htm
    However, even though it may be solid core, it's still an 18AWG cable, although, I don't really see a problem, if you've got the cash, try it. :)
  • cmy330go
    Thanks for the info! It just doesn't seem that cable that small could handle the load. Well I guess it's time to give it a try.
    Thanks Again.
    HT
    2 CH
  • candyliquor35m
    candyliquor35m Posts: 2,267
    How much is it? Ask for electrical wire at Home Depot or Lowes if you want to comparison shop.
    I like to use 10 awg on my sda's but have only tried the stranded for now.
  • cmy330go
    I think it was $4 for 60ft. At that price how could anyone resist trying it?
    HT
    2 CH
    F1nut Posts: 52,150
    Waste of $4, IMO.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    So you've tried it then Jesse?
  • cmy330go
    F1nut wrote:
    Waste of $4, IMO.
    Why? Have you tried it?
    HT
    2 CH
  • RuSsMaN
    Of course he hasn't, give it a whirl.
    F1nut Posts: 52,150
    If I had tried it I wouldn't have added "IMO", now would I!?! There are some things in this hobby that one doesn't have to try because logic and knowledge are more than enough. So Russ, have you wasted the $4?
    F1nut Posts: 52,150
    Great advice Russ. You know better, so why encourage him to waste his money?
  • TroyD
    TroyD Posts: 13,124
    Maybe I'm lost, but who is raving about this solid core hookup wire to begin with??
    BDT
  • cmy330go
    I'm not concerned about the $4.
    BDT
    It started quite some time ago when believe it or not stereophile gave it a favorable review and added it to their recommended components list. Now normally I don't much care what stereophile does or does not recommend. I mean you can't help but wonder how much their pockets are lined by many manufacturers. But I figured in this case, Radio Shack probably isn't a big money maker for them. I have also seen mention of it here and on other forums. And besides......It's only $4 freakin' dollars to find out.
    Maybe I'll have time tomorrow to try it.
    HT
    2 CH
    F1nut Posts: 52,150
    JHC, it's not even shielded!
  • TroyD
    TroyD Posts: 13,124
    I've got a bunch of rat shack wire.
    Really makes those Pioneer CS-88a's SING.
    It's basic wire. Nothing more nothing less.
    BDT
  • gidrah
    gidrah Posts: 3,049
    The wire in question sounds very good IMHO. If you can get some red and some black of the same stuff it works real well. If you can't it just isn't as easy. This wire is a single run and you'll need to double it up (1+/1-). I also suggest that you add an extra 10-15% and twist them. It's easy to do if you just put the ends in a drill. This will create a sort of shielding in that any interference will cancel each other. Most speaker wire don't really require shielding anyways,unless they are very long or laying on your power cables.
    Make it Funky! :)
  • McLoki
    McLoki Posts: 5,231
    edited December 2005
    For $5.46 you could get 2 7' strands of 12guage belden speaker wire from Blue Jeans Cable. (Heck for $8.26 you could get 10 guage) I am not saying it is gods gift to wire, but at least you won't have to ask if it will work for your speakers or not. :)
    Michael
    Edit - I know its not the question you asked, but still just wanted to point out you can get something decent for not alot of dough. I know you said the $4.00 didn't really matter that much but if you are going to test solid core, get some electrical wire from home depot or lowes and test some decent guage that is shielded. - i.e. if I wanted to test out stranded wire and purchased 18guage lamp cord to do it with, I may not like it either compared to whatever I was running.
  • RuSsMaN
    I love the concern over his wasting of FOUR dollars. Four HUNDRED, I could understand, but four? Of course I've tried it. Various solid core, cat5 braided, etc, etc.
    IMO? I understand it's your opinion Jesse, but based on what? Actual experience? A peer's experience? Just because it doesn't make sense how it could possibly sound good? Something you read on the internet?
    My thoughts on it? I'll let him form his own conclusions, afterwards, if he would like, I'll happily share my thoughts. He's got an open audio mind, I'll support and encourage that - it's all too rare these days.
    Cheers,
    Russ
  • steveinaz
    steveinaz Posts: 19,546
    Give the RS a shot. If you want, twist a pair or 3 together per post, just strip the last inch or so of insulation on each length, twist them into 1 conductor, connect and enjoy.
    You have to admit that anytime the snobs at Stereophile are willing to give the "nod" to a $6 roll of wire---there's something to it.
  • cmy330go
    gidrah, McLoki, RuSsMaN, steveinaz
    Thanks for the support guys! :)
    I don't expect this to be the best cable in the world. In fact I have my serious doubts that it will be better than the Monster Z (aka Poo) I have now. But sometimes I really enjoy seeing how much performance I can get out of budget items. For example I have an older pair of energy exl-16 bookshelf speakers that retailed for only $300 new. Yes, I have graduated to bigger and better, but sometimes I can't help but hook them up and be amazed. Do they sound better than my LSi's??? Hell No! But there is one thing they are amazing at.....Imaging. Those little guys set a soundstage that is stagering. They don't have the overall detail, response, or refinement of the LSis, but I still love to hear what they can do FOR THE MONEY!
    One of my favorite things about this hobby, besides the music, is the learning how it all works. Which usually means going back to basics. In fact tomorrow I should be receiving all the parts I need to build 3 headphone amps (total cost $70). All this so I can learn more about opamps and different circuits. I am also looking forward to making my Ipod sound much better, but I sure don't expect it to sound like a Musical Fidelity X-Can either.
    All I'm saying is.....just becuase I may ask about some low end equipment or cheap tweaks from time to time.....this doesn't mean I'm another newbie freak who wants to run my home theater system off of a car audio amp, battery, and a set of jumper cables.
    Ok sorry. That kinda turned into a bit of a rant. But I think that makes my point. For some of us there is more to the hobby than just getting the best sound.
    Thanks again guys!!! :D;)
    Dave
    HT
    2 CH
  • steveinaz
    Nothing wrong with trying to get the most bang for your buck---hell, I live by it!
    F1nut Posts: 52,150
    Sure there's nothing wrong with trying different stuff, however I stand by my comments on this one.
  • TroyD
    TroyD Posts: 13,124
    Anybody ever try standing thier center channel on it's end? I hear that works wonders!
    thank you, BDT
    (there are a few oldtimers that will get this)
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    solid conductor wire does not have the current carrying capabilities of stranded wire of the same gauge.
    the "skin effect" of electromagnetic theory dictates that the majority (well over 50%) of any given signal's current travel's along the outer "skin" of a conductor. That being said, 18 gauge wire of many many many very very thin strands will give you more cross sectional area for conduction of current than a single solid conductor piece of 18 awg.
    The skin effect is especially present with AC signals of high voltage (relative). While it is present at DC, it is not as important. None the less... high quality, high current DC power line is still made up of as many as 5,000 strands of oxygen free tinned copper -- if only to avoid trouble.
    "Rat Shack" as you so aptly name them - does sell wire of oxygen free copper - it's not virgin copper, but it's not dog **** either. However, the problem with most radio shack stranded speaker wire is that the strands are somewhat thick. There may only be 5 or 7 strands inside a piece of 18 gauge, if that. A better quality wire such as Esoteric Audio will have at least 30 to 50 strands inside a piece of 18 awg, thus providing lower DCR, higher current carrying capability, and more flexibility within the line. Often, better grades of copper are used. Virgin copper will cost you $$$ though. There is no need to shield speaker wire provided that you are not running it along the path of AC Wall Outlet power lines. The high voltage of the amplifier output to the speaker is strong enough to resist most any interference (20 to 30 volts will not be muddied up by a 0.1 v insurgence of noise). However, as stated, running it next to power lines is a no no. Even with a shielded speaker wire, that's a no no. Sometimes you're stuck tough and have "gotta do what you gotta do". I suppose thats why anybody even makes a shielded speaker wire.
    The Artist formerly known as PoweredByDodge
  • cmy330go
    Thanks for the tech refresher. I remember some of this from circuit analysis class in college. I loved this class because it often turned into an audio discussion. We also had a debate going for awhile regarding solid core vs. stranded speaker cable. There was some question as to whether the electrons transfering from strand to strand in speaker cable would effect the sound. (I'm sure many here have had the same discussion) I can't say that we ever completely settled the debate. However the majority were in the solid core camp. Unfortunately we never got around to doing blind tests. I guess I might have to have a friend over to conduct some. Maybe I can settle this once and for all......at least in my mind. :)
    HT
    2 CH
  • BIZILL
    BIZILL Posts: 5,432
    you wanna energize them speakers with something different? i say, "more power to ya!" ... pun intended!!!
    give us an update when you get things going.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • McLoki
    McLoki Posts: 5,231
    I don't think this works exactly like you are thinking. Multi stranded wire will be able to transfer slightly more current than solid guage but not much.
    Think of 20 pipes bound together. Current will only travel where the outside of a pipe meets the air. (not another pipe) The entire outside will conduct current as well as the small space created where the pipes almost touch but due to them being round rather than square they do not. Shrink that down, and you have your stranded speaker wire.
    To have the effect you are thinking of would require insulated strands and would be accomplished by many of the DIY cables created using cat-5 network cable.
    Michael
    Edit - I am not saying there will or will not be a difference in sound between solid core wire and stranded, just that your description of skin effect could be misinterpreted.
  • PoweredByDodge
    stranded wires are not vacuum sealed, that is to say that there exists air space between each conductor - not 100% area, but a good amount... see diagram.
    indivudual conductors are not flat, they are round, and no matter how small it may appear to the naked eye, the phenomenon demonstrated in the diagram occurs on a tiny tiny tiny scale with each and every individual strand within a stranded piece of line. This is why 3 strand wire is not really any better than single conductor. However, hundreds, even thousands of the little buggers work wonders.
    None the less... when you get down to it, stranded or solid, there are but 2 things to worry about. 1) voltage loss along the line. 2) induced noise.
    so keep it away from noise inducing things, and use an appropriate gauge. its just that with a high strand count (say 50 to 70 strands for 14 gauge), you can carry significantly more current without suffering any appreciable voltage loss.
    debate it all you want, but inductors induce hysterisis (spelling is probably wrong on that), and a simple stranded wire is far far far far from an inductor.
  • candyliquor35m
    I just did a side by side comparison of 10 awg stranded vs 10 awg solid core which isn't as good as a blind comparison but I closed my eyes ok. Also I used the left channel vs the right so I wasn't exactly comparing apples to apples.
    The stranded was louder which makes me believe it carries more current but the solid won my ears over very quickly. The clarity, preciseness and instrument separation blew me away. It was much easier on my ears than the loud boomy jumbled sound coming from the stranded and man did it make my sl2000's dance.
    Speaks: SDA 2B
    Pre: Audio Experience Symphonies Tube
    CD: Sony SCD-C2000ES
    Amp: Undisclosed Tube
  • cmy330go
    Thanks for the input. I have been too busy to try a comparison myself. Maybe one of these days. :rolleyes:
    HT
    2 CH
  • PoweredByDodge
    10 gauge solid core must be about as stiff as a heavy coat hanger... that doesn't lend very well to routing under carpets, etc etc etc... but if you prefer it and feel there's a difference in sound, then by all means go with it - being happy is what's most important.
