which speakers schould I buy??
venicebeach
Hello
I have a big question!! Which speakers schould I buy? I have now The rti 12 and the csi25 center speaker! Still I have for Rear sound MBQUART MCS 1090
now I wanna change the MBQUARTS maybe for polk´s.
maybe a new center? The CSI 3 or is the CSi 25 enough?
an for rear maybe the rti 8 or rti 4 or r 30/50. What kind is the perfect match?
Are small Loudspeakers for rear enough? The MB´s are big speakers sounds good or can I stay on this collection? The MB was expensive 5000,- $
How big is the different from soundfield? I listen also much music!!! Not only movie!!!
I have the Yamaha RX-V 1500 ampflier.
Hope to get soon help from you cause I live in germany an my store sell them for more than 70% under normal price e.x. (pair)
rti 8 for 499.-$
rti 4 for 199,-$
r 30 for 135,-$ r 50 222,- $
csi 3 for 175.-$
I got the Rti 12 for only 700,-$ pair
thx a lot
Olly
rti 8 for 499.-$
rti 4 for 199,-$
csi 3 for 175.-$
thx a lot
Olly
Post edited by venicebeach on
match Pure Acoustics to POLK? How good is PUREACOUSTICS?? I like the DREAM77 but I never heard it but I think POLK is MUCH BETTER ) here in germany both are very unpopular....dam! All people only want to buy CANTON JBL OR MAGNAT but they cost a lot more but doesn´t sound better!!
last reply
I have follow possibilities
only the rti 8 for rear
or the r30/50 and the new center csi 3
or the center csi3 and the rti 4
or only a new center and stay at the MB
what would be the best result? -
I'd add a comment, but you seem to be doing pretty good on your own.
Cheers,
Russ
(get RTi all the way around)Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Csi5 center (you got the twelves, get the bigger center to match. get rti4 of 6 for surround) if you cant get the CSi5, then get the CSi3 if you have to, but get that center timbre matched to the RTi12's it will make a difference.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
is the sound much different from the r50 to the rti 4?
