CD recorder
keith allen
I dont have a cd burner on my pc so I was thinking about getting one,and then I thought maybe I would get a cd recorder,I want the best reproduction I can get...what do ya think is the best option?
Post edited by keith allen on
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
I should have added,I want to spend $300 max
I'd just get a CD Burner, more flexibility...and cheaper...
How about $24.99:
http://www.newegg.com/Product/Product.asp?Item=N82E16827106996
Personally, I would just get a DVD burner, $42.99, it will do CD's also:
http://www.newegg.com/Product/Product.asp?Item=N82E16827106990 -
I have a stand alone Sony with SBM (super bit mapping) and it is an awesome recorder. For copying CD's it makes a lot more sense to do it on a pc as the discs are cheaper and the process is faster. For $300 these days you can buy a pc with a player and burner.Vinyl, the final frontier...
