CD Players
Reagan
Folks, I have re-vamped my system from the speakers back towards the source. SRS 1.2TL's with Cobalt Cables (ultimate speaker cables) connected (not bi-wired) to a B&K Reference 200.2. The Amp is fed with Cobalt Cable interconnects from my NAD receiver with the jumpers removed (pre-amp section used only). The NAD is fed with Cobalt Cable interconnects from my weakest link in the system which is a run-of-the-mill Toshiba carousel DVD/CD player. It seems obvious that my next two areas on which I should focus are the CD player and the pre-amp. I am looking for suggestions. I am considering a Denon cd player in the $300 range, but I am will to increase that budget depending on how much of a quality difference I can buy. I definately need to stay under $1000 for the CD player. Thanks!
Speakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
Amplification: ARC Reference 110 w/KT150s; Cary Audio SLP-05 w/Ultimate Upgrade
Vinyl: VPI HW19 MK III (Heavily Modded); Origin Live Silver Tonearm; Hana ML Cart; Pete Riggle VTAF; VPI TNT Platter; SAMA; Iphono3
Digital: Aurender N100H; Benchmark DAC1
Post edited by Reagan on
- Cambridge Audio D500SE or 640C...$499'ish cheaper on Ebay
- Rega Planet 2000...$795 (upscale audio)
- Ah! Njoe Tjoeb....$749 (upscale audio)
- Music Hall CD 25.2....$599 (audio advisor)
- The list goes on and on...
OR..the BEST move:
Buy a Benchmark DAC for $995, continue using your DVD for time being and run it thru the Benchmark. Upgrade CDP later in the year when you have the bucks. (if you even think you need to after adding the DAC).
Benefits of an external DAC:
- You can eventually move to a single source player, such as a DVD--flexibility. This is my plan for the near future. I'm gonna sell my CDP and cheapo DVD and buy a Marantz DV-7600 DVD player and use it universally, running thru my Benchmark DAC1.
- You can move later to a carousel CDP and/or DVD and not have to worry about sound quality suffering.
- It's not really necessary to spend a ton of money on a transport if you have a good quality DAC.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
If your budget is up to $1k, then get the JoLida tubed cdp or the Ah! Tjoeb cdp. Both can be had NIB for under $1k without any mods done. For around $400, you can get a Dodd ELP tubed pre-amp. OR if you're patient you can get both for under $1k on the pre-owned market.
The Onix 88 something cdp is basically the exact same unit as the Music Hall that Steve mentioned in the above post and it's less money and one of the best bargains on the market from what I've read."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Another option would be to pick-up a CDP like the onix, and then Ebay a nice preamp---this could easily be done under a grand, and your speaker/amp combo is definitely worthy of the upgrades...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Thanks for the response! I am obviously still confused about the DAC technology. This will apparently make my cheap DVD/CD player sound better. How does this work in practical terms. Also, if I start with a DAC, will it still make sense to save my pennies for a CDP upgrade?Speakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
Digital: Aurender N100H; Benchmark DAC1 -
I own a Jolida JD-100, so I admit I'm biased. There's been some good ideas posted. My thought we be to check A-Gon for a used JD-100 or other CDP that's been mentioned.
Also, you may want to consider going anothe router and taking a foray into PC-HD based digital wireless feeds, a trend that seems to be making increased inroads on more audio systems. Definitely worth reading up on, try AudioCircles, etc. -
You should also check out Rotel's RCD-1072. Top notch player for 699.00Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
You need a DAC when your sources conversion of the signal is not adequate.
I would recommend you leave the video to the DVD and get a dedicated CD player. The ones mentioned by the others would be a nice upgrade for you. Think discreet circuitry, power supplies, shielding and so on.
RT1 -
cfrizz wrote:You should also check out Rotel's RCD-1072. Top notch player for 699.00
YES. Sorry Cathy, I always forget the Rotel---funny thing is, it's one of my favorites!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Is it just me or does everytime you see "Rotel", does it make you want to go the the store and buy some Velveeta and a can of Rotel and make some cheese dip??? :cool:"SOME PEOPLE CALL ME MAURICE,
Reagan wrote:Thanks for the response! I am obviously still confused about the DAC technology. This will apparently make my cheap DVD/CD player sound better. How does this work in practical terms. Also, if I start with a DAC, will it still make sense to save my pennies for a CDP upgrade?
An external DAC takes over the digital to analog conversion. When you use an external DAC, you connect your player to it by using the digital output; optical, coax, bnc, aes/ebu---depending on what your player provides as an output---yours is probably optical (aka: Toslink).
External DAC's usually have better digital-to-analog conversion DAC's, a better analog output section, etc, etc. Because of this, they can in theory make a cheap player sound like an expensive one--in practice this is usually true, but it's a little more complicated, I don't have the expertise to speak intelligently about the differences in transports.
It's the same concept as buying an external power amp versus using the amp section in a receiver---there's less constraint on design and budget.
As far as saving for a later CDP upgrade, it depends on how well your current transport works with the DAC; it may breathe new life into it (it will definitely improve the sound), and you may find that a CDP upgrade isn't needed...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
The NAD C542 or the S500i."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
If you buy a $1k DAC, there is no way that you will find yourself content with a $100 transport. Your mind will never let the $$$ imbalance work.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Agree, the idea is to create an "upgrade" path...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
... and do it in the right section of the forum...More later,
Tour...
Vox Copuli
