RT 25i to RT35i
bassaholic
I am currently using RT 25i's in my system. There is a pair of RT 35i's in the Flea. Does anyone know if there is much of a difference soundwise between the two?
Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
SVS PB13 Ultra & PSW650
Monster Power 3250 amp
Monster Power 2250 amp
Monster Power HDP-2500 surge pro.
Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
RTiA9-fronts
CSiA6-center
RT55i-surrounds
Post edited by bassaholic on
The RT35i are a much better speaker, IMO.
They sound more neautral, better bass response. They are the better of the two, thats for sure.
If the price is right... get it - wont be sorry.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I would stick with the RT25i. Overall it is a much better speaker. Since you are using it as a rear surround the increased bass (although somewhat bloated in the RT35i vs RT25i) is of little value. The RT35i was one of the weakest of that family of speakers IMO (RTxxi)."Just because youre offended doesnt mean youre right." - Ricky Gervais
