DLP Bulbs?
The Darkhorse
I am looking for a replacment bulb for a 62" DLP Mitsu 62628. Any ideas where I could find one?
Post edited by The Darkhorse on
Frank Z wrote:
I saw that place but it seems they are all for projectors not RPDLPs -
Try a Google search with your lamp PN.
Frank Z wrote:Try a Google search with your lamp PN.
Id love to...dont know what it is though -
Hmmmmm, the best I could do was this manual.....
http://www.mitsubishi-tv.com/common/getfile.asp?uuid={42231470-02AB-47C8-A152-C4BD301EA828}
Page 99 has the bulb replaceemnt procedure and also lists the bulb p/n. Your manaul might do the same. -
On DLP replacement bulbs, your supposed to order them from the manufacturer. I think mits even has a program where if you send them your old lamp housing for recycling, they give you some money back.
The Manual?!?!? You think I look in the manual?!?!? What kind of psycho do you take me for?!?!? (jokin of course...I never thought of that...someone slap me?)
Hey Darkhorse, did your bulb already go out or are you just looking to get a extra one for when it does go out?Money Talks, Mine says Goodbye Rob!!!!
If you have no luck getting one from Mits direct, order one through the parts department of the store you bought the TV at.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner
