Question about Video Upconversion for the Pioneer Elite VSX-56TXi A/V Receiver
team_canada
My question is, should I be able to have all video sources connected to the receiver whether it's s-video or component video run from the receiver through component video to the television?
Right now the dvd player is hooked to the receiver via component video and then component video out from the receiver to the television. I have had to hook the s-video up directly to my television from my digital cable box in order to get a picture. My digital box does not have component video.
In order to view cable TV I have to use Video 1 on my television and to view dvd's I have to use Video 2. Is there a way to view all sources through the same input? It looks like it has this function but I can't seem to figure it out.
Any help is appreciated!
POLKPIONEER SYSTEM
Receiver - Pioneer Elite VSX-56TXi
Amp - Pioneer Elite M-10X
DVD Player - Pioneer Elite DV-59AVi
Front Speakers - polkaudio RTi70's
Center Channel - polkaudio CS400i
Sub - polkaudio PSW202
Surround Speakers - polkaudio R15's (7.1 System)
Speaker Cable - Unity Monster Link Biwire
(Fronts & Center)
TOTAL SPEAKER UPGRADE COMING SOON!!
(Fronts & Center)
Post edited by team_canada on
Yes but I am not sure if you tried running the s-video through the receiver and it didn't work or if you think the input type must match the output.
I have a VSX54tx which should be the same as far as video switching is concerned. I have my Phillips SAT box s-video out and Sony DVD component out hooked up to my receiver and run one component out to my TV. This setup works fine for me. The is no other video connection to my TV. My SAT box actually has component out but the colors were way too over saturated for my taste, the s-video looks much better. The DVD looks best with component.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
MADGSF wrote:Yes but I am not sure if you tried running the s-video through the receiver and it didn't work or if you think the input type must match the output.
Hey MADGSF, yes I did try running the s-video through the receiver by way of the TV/SAT In as per the manual but could not get any video output on my television that was hooked up from the receiver through the component video monitor out.
Did I hook it up to the wrong input??POLKPIONEER SYSTEM
(Fronts & Center)
TOTAL SPEAKER UPGRADE COMING SOON!! -
does your receiver perform s-video up-conversion to component. being that it's an elite, i'd presume so.... yes it does.
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4155_123728213_tab=B,00.html?compName=PNA_ProductDetailComponent
it should work.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments.
