SVS & PEQ
dholmes
dholmes Posts: 1,136
How important is to use the peq on the SVS sub? Also whats the easiest way to use it without using a computer. thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • tryrrthg
    tryrrthg Posts: 1,896
    edited November 2005
    use an SPL meter and test tones. without seeing a plot of your response no one can tell you how important the PEQ is.
    download the test tones in the link below.
    http://www.snapbug.ws/sinewaves/
    You should at least get 20 hz to 90 hz and plot your response in an excel spreadsheet (don't forget to use the correction factors for the radio shack SPL meter). I've attached the spreadsheet I made up that makes all the corrections. All you have to do is enter your readings into the table, the spreadsheet graphs everything for you. Let me know if you have any questions about it.
    EDIT: if you can't use a computer you'll have to get out some trusty graph paper and plot your response by hand, otherwise just forget about the PEQ and set your sub up by ear.
  • dholmes
    Thanks, Ive got a Ht dvd guide with several test tones, would that work with my rat shack meter?
