Air tight MM120's
Systems
Hey, I built the box for my 2 12's and it came out nice. Think it came out to like .876 cubic feet. The only thing I am wondering is when then system is off and you push on the subs. You can hear air flowing out the back. I used wood glue and caulking on the box. The only problem is the terminals. I bought them at Radio Shack (it was the only thing open on sunday). If I take my hand and throw it over the terminal, the sub is air tight and almost impossible to push on it. The subs sounded great, and I didn't even realize this untill today. So.. How important is it that it is air tight? will I hear a difference? I plan on taking some caulk and throwing it all over the back of the terminal to stop that, just wanted to know how important it is. Thanks
LowRam
LowRam
Testing
Testing
Testing
Testing
Testing
Should i not be able to move the cone very much by hand? I have a sealed enclosure for a single mm120, but i can move the cone fairly easily by hand, is this an indication that i have a leaking box, and i just haven't noticed?
thanksTesting
Testing
Testing
