Another upgrade thread
RichterCAG
Centrepiece of my gear is an AVR330. I am planning to upgrade somtime between three or four months from now.
Assuming HDDVD/Bluray will use 6/8 channel direct inputs, my next reciever must have this feature.
My top current choices are either a 635 or 7300.
Point - how much more powerful is the 7300 over a 635? Set aside the various technical ratings of each amp. I know the power ratings are truly constant per channel for the respective recievers Harman produces. I am talking about merciless, naked force with all the bells&whistles.
My two big towers are Rti10s.
The other speakers comprising my 7.1 are of less then equal calibre.
Naturally I will upgrade these overtime but for the immedate near future, the reciever must come. Movies featuring aggressive sound tracks partiucuarly Revenge of the Sith and Matrix Revolutions are the type of sound I want.
JVC 61FN97
Harman Kardon avr330
RTi10 l/r front
CSi5 center
Atrium 45 (four for the surrounds.)
RTi10 l/r front
CSi5 center
Post edited by RichterCAG on
No one is actualy going to respond to this, eh?
Not suprising.JVC 61FN97
RTi10 l/r front
CSi5 center
Atrium 45 (four for the surrounds.) -
The 635 will get you more out of those RTi10. The 7300 has much more power, there is no comparison. Have you read the lab measurements of those units from the H.T. & S&V mag?
If the 330 has all the features you need and power is all you're lacking mabe adding a seprate amp might be an option for you to consider.Outlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
Kenwood Excelon KDC-X891
JL Audio 300/V2
Polk Audio SR 6500 - Fronts
Polk Audio DB651 - Rear
2 -10" Treo Subs
Interfire IB 2600C sub amp
Sirius Sat radio
Ipod connection -
mrmusicman wrote:If the 330 has all the features you need and power is all you're lacking mabe adding a seprate amp might be an option for you to consider.More later,
Tour...
Vox Copuli
