Lsi9 Question
Lsi9
Lsi9 Posts: 616
edited December 2005 in Speakers
I am thinking of using an Lsi9 as a center channel, anybody know where I can order just one?
If anyone has a Lsi9 CC, how did you manage it?
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP
Post edited by Lsi9 on
  • Tour2ma
    Tour2ma Posts: 10,177
    edited November 2005
    Search should turn up discussions as others have done this.
    Every once in a while you see a single on ebay.
    More later,
    Tour...
    Vox Copuli
  • trees
    trees Posts: 71
    Been looking for a single dinged-up 7 or 9 to put between my sofa and back wall as a 6th speaker. Appearance not an issue as only the spiders will see it.
    If you find a used pair (7 or 9) with one scratched and one good, I'd buy the beat-up one from you. Maybe we could both come out ahead with this.
    Depends on price though.
    Trees
  • Eric W
    Eric W Posts: 556
    Hi, we have heard of many customers using a 3rd LSi9 for the center channel with great success.
    First try your dealer, many times they are willing to split up a set for this very reason, or for 6.1 systems. If you are unable to find one this way, you can get a single one from us directly.
    -Eric
    -Polk Audio
  • tonygeno
    tonygeno Posts: 34
    Eric:
    Why develop the LSiC then? Is the 9 a superior center, if space is not an issue?
  • Lsi9
    Lsi9 Posts: 616
    I am in midst of listening to two RM3000 satellites (wired parallel) as a center channel. My initial impressions are that the 3000s are more closely matched to my Lsi9s than my cs350, the 350 during test tones has a emphasis on the lower register of mid-range, while the LSi9s don't.
    My guess is that this is inherant in a lot of CCs, the 3000s match my LSi9s closer in test tones...I don't think I like the chesty sound in a CC, I'd rather have a uniform sound across the soundstage...at first the 3000s exhibited less mid-range than I would have liked but then I adjusted the crossover on them from a 150hz to 80hz and it sounded great.
    Overall the treble sounds cleaner in the center signal
    I think Im going to stick with this setup.
    So, its LSi9s on R/L, two 3000's in unison for the center channel and two more 3000s for R/L surrounds
    plus my HSU 1220TN anchoring it all
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • bankshot
    bankshot Posts: 76
    The LSi9 has a full bodied sound to it that makes it blend great with a sub-woofer.
    The LSic sounds good but IMO it cant keep up with the 9s in lower midrange/upper bass.
    Outlaw M200s
    Outlaw ICBM
    Yamaha reciver
    Panasonic: AE900U
    POLK LSi 15s
    POLK LSi 9s
    POLK LSi C
  • Airplay355
    Airplay355 Posts: 4,298
    I think you can order single speakers from crutchfield.
  • Ferres
    Ferres Posts: 310
    I'm dabbling with the idea of a dual lsi9 center using a y-connector hooked up to one power amp. :P
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • bankshot
    bankshot Posts: 76
    How would you set up the speakers, Im thinking about doing that myself.
    Outlaw M200s
    Outlaw ICBM
    Yamaha reciver
    Panasonic: AE900U
    POLK LSi 15s
    POLK LSi 9s
    POLK LSi C
  • Ferres
    Ferres Posts: 310
    You could set it up like standard stereo on the power amp. What to do is have the 'center' rca split into two via y-connector and have them plugged to the left and right channels of the power-amp. So the same signal will be sent through the left and right channels.
    This would double the output of the center so it may need to be toned down a bit. :D
  • bankshot
    bankshot Posts: 76
    Cool, how do you oriantate the speakers.
    Outlaw M200s
    Outlaw ICBM
    Yamaha reciver
    Panasonic: AE900U
    POLK LSi 15s
    POLK LSi 9s
    POLK LSi C
  • Ferres
    Ferres Posts: 310
    I'd set them up a little closer together between the 'mains' speakers. This should give a nice impact for dialogues.
  • bankshot
    bankshot Posts: 76
    Side by side or one on top of the other.
    Outlaw M200s
    Outlaw ICBM
    Yamaha reciver
    Panasonic: AE900U
    POLK LSi 15s
    POLK LSi 9s
    POLK LSi C
  • Ferres
    Ferres Posts: 310
    Side by side like you have it on stereo. It may even produce a phantom center working together that way. Not sure, but regardless, it will put a lot of oomph to the center.
  • Lsi9
    Lsi9 Posts: 616
    I set up the both Rm3000 satellites as a center channel w/ sub so the cc is set to Large as well as the rm3000 surrounds w/ sub
    Lsi9s are set to small and now the front soundstage matches seamlessly along with the front to back imaging...much better setup than using the cs350 set to small...amazing actually
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • speakergeek
    speakergeek Posts: 555
    bankshot wrote:
    The LSi9 has a full bodied sound to it...
    Nice. Kinda like a full bodied wine eh? :p
  • wingnut4772
    wingnut4772 Posts: 7,519
    I had to order a pair and then I sold the extra one on Ebay for someone else also looking to use it as a center. I tried Crutchfield and they said that they only sold them by the pair. I used to have the LSIC and for some reason I used to have to set it way hot to hear the dialog clearly. I am very happy with the 9 as a center.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
