csi 5 set to small? Sounded better at large?
james vaughan
As I have read many times on this forum before, you should always set your speakers to small and not large. Was goofing around the other night going back and forth with the new center channel and was amazed how how mutch more depth or vocal base and I mean in a clean way was added to the center buy switching it to large. Now I always read and rarely post but was curious as to why this made a posative difference in my system? My left and rights are the rt 55i's and I got a pop out of the right main when set to large. Crossover is set to 80hrz. So I guess I will have to buy the rti12 to keep up with the center. Am running 250 watts to the center and 300 per side to the left and right. Just was not sure why the center channel would not loose its integrety as the rt 55i did at the same volume. Was told the drivers are the same. Also made me wonder about the bookshelf versus floor standing for better overall re3sponse in the system.
Thanks for any replys.
Post edited by james vaughan on
Two ?'s...
1. What sub are you using?
2. Have you calibrated your HT?More later,
Tour...
Vox Copuli
setting your speakers to small isn't written in stone. it's only a suggestion. most people in their set up's will yeild the best bass output from their subwoofer if all their other speakers are set to small.
but some front/mains can handle a decent amount of bass..so large is ok there.
try it both ways.. and see what sounds best to you.PolkFest 2012, who's going>?
Tour2ma wrote:Two ?'s...
Yes it is calibrated.
Again thank you for your help. -
James,
First, before I forget again.. Welcome to the Club. Second, db's correct, there is no one way you have to go. Most here favor small for any number of reasons, but some prefer large.
I'm not surprised the CSi5 is sounding different from the 55i's when the added LF info is routed to it. While I do not think the drivers are same, I'm sure the 5's power ports are going to ensure a difference.
I think the 5 may just be getting slightly louder, which makes it seem disproportionally richer. To be fair, you'd need to recalibrate the system when set to large.
What still concerns me is the right channel pop. Is the LFE routed to the sub in both cases, i.e., speakers large and small?More later,
Tour...
Vox Copuli
Tour2ma wrote:James,
Are you for floorstanding speakers? I am thinking it might improve my systems overall sound. I like the more in your face but not shrill sound like at a theater, or at least that is what I am trying to achieve.
Thank you all agian. -
The "very big improvement" suggests a blend issue with your sub, but flat FR is an individual taste.
As high as you are crossing over with LFE going to the sub, I'm kinda surprised the 55 has an issue unless a driver is going bad. I'd check out the offending 55... When it popped was it a strong right channel effect, or was the signal to the left similar?
As for 10's or 12's... for music sans sub either might be an improvement (only holding back here due to no experience with the 55's). Of all the current Polk lines, including the LSi's, the RTi10's are my favorite.
Yes, the 10's will dig deeper and yes, they handle more power, but in HT crossed out at 80 Hz, I don't see any major benefit. The 55's already can handle all your 3805 can throw.More later,
Tour...
Vox Copuli
I've been running my theater speakers on large yesterday. yes, the bass out put suffers a little, especially on music, but I find during bass heavy scenes in movies that the bass is more accurate and natural. in other words, I'll be running the speaks in Large for a while.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Audiophonics AB310 preamp, DIY1200as2 Icepower Amp, Wiim pro streamer and Topping E70 Velvet DAC, California Audio Labs DX1 CD player, Polk LSi9 with modified crossovers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Tour2ma wrote:The "very big improvement" suggests a blend issue with your sub, but flat FR is an individual taste.
It was not a popping that speaker made but more of a over stressed sound I just didnt no how to describe it and it only came from the right speaker but the scene deliverd equal info to both left and right at that particular moment.
Very hungry for info here, Why do you like towers better and what made you go with the 10 over the 12 in the rti series? What I discoverd the other day really makes me wonder about the whole small speaker issue at least in the fronts keeping bookshelf sized in the back but going bigger up front.
Thank you all again for input and still learning, spend more time reading then posting until somthing comes up like this. Thanks again. -
ohskigod wrote:I've been running my theater speakers on large yesterday. yes, the bass out put suffers a little, especially on music, but I find during bass heavy scenes in movies that the bass is more accurate and natural. in other words, I'll be running the speaks in Large for a while.
you dont have to buy rti12s to keep up with the center. The rti 6 has about the same frequency response as the csi5, and if you want lower responses look at the rti 8 or 10. If you want the rti12s, go ahead, but expect to buy a sperate amp to push em. As for the small vs large, the ideal solution is to set the center at small and set the center crossover as low as the speaker is designed for. With the rti5, i'd do small with a crossover of 50 - 60hz. The higher you set the crossover, the less "full" it will sound. If you put the center channel on large, then you will be feeding it frequencies that it was not designed for, and will make it sound worse than if it was crossovered properly (properly being relative to how it sounds to you). using crossovers is also important in subwoofer integration, so unless your speaker can handle really low frequencies, dont set it to large.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
sickicw wrote:you dont have to buy rti12s to keep up with the center. The rti 6 has about the same frequency response as the csi5, and if you want lower responses look at the rti 8 or 10. If you want the rti12s, go ahead, but expect to buy a sperate amp to push em. As for the small vs large, the ideal solution is to set the center at small and set the center crossover as low as the speaker is designed for. With the rti5, i'd do small with a crossover of 50 - 60hz. The higher you set the crossover, the less "full" it will sound. If you put the center channel on large, then you will be feeding it frequencies that it was not designed for, and will make it sound worse than if it was crossovered properly (properly being relative to how it sounds to you). using crossovers is also important in subwoofer integration, so unless your speaker can handle really low frequencies, dont set it to large.
Thnaks again. -
yea, setting to small usually just means that you are going to use the built in crossover of the receiver or pre amp. If you want more bass from your main speakers, just use a lower crossover value.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
No disrespect, sickicw, but you do not want to drop the AVR's x-over near the point where the speaker FR is rolling off naturally... that's inviting double filtering in the x-over region. A 50-60 Hz setting for the CSi5 (-3 db @ 55 Hz) or the RTi6's (-3 db @ 50 Hz) is just too low... 80 Hz is a good choice.
james,
You are correct about the full range signal going to a given speaker if it is set to large, but I think (not 100% sure about the 3805) the cross-over is still routing the <80 Hz to the sub. So the less than 80 Hz info is now being produced by multiple sources. This will have a warming effect much like the old "Loudness" contour switch which at low volume levels boosted some of the lower frequencies signal. (osg, not sure how your Outlaw manages bass, but the above may be what you are experiencing as well.)
While the above may be enjoyable in the short term, it may start to seem artifical in the long term... or not. Again a change from small to large, or vice versa, means you should recalibrate your HT... but in the end, it is what sounds best to you.
On your sub-sat comment... That's essentially what your 55's/ SVS combo or any other is. So the goal is the same: seamless integration. And that means careful calibration
As for the RTi10's... I don't own them or any "modern" Polks, just did an extensive audition for grins a while back. I felt the 12's bass was a little bloated in comparison to the 10's, but you really have to decide for yourself.More later,
Tour...
Vox Copuli
Tour2ma wrote:No disrespect, sickicw, but you do not want to drop the AVR's x-over near the point where the speaker FR is rolling off naturally... that's inviting double filtering in the x-over region. A 50-60 Hz setting for the CSi5 (-3 db @ 55 Hz) or the RTi6's (-3 db @ 50 Hz) is just too low... 80 Hz is a good choice.
james,
Thanks again. -
You're welcome... Let us know what you end up doing.More later,
Tour...
Vox Copuli
