Amperex 7308 goldpins
W WALDECKER
I just ordered a matched and balanced Quad of Amperex 7308s for my Anthem Pre 1L preamplifier. does $360.00 for the Quad seem like the going rate for these twin triodes ? thanks....WCW III
Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
Post edited by W WALDECKER on
Man, I want some of those sooooo bad, but I just can't plop down that kind of duckets for them at this time. All i can say about the price is that I've seen them for much more, so it would seem to be a good deal."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
for a quad, matched id say yeah.. Great tube. it's still alot of cash for 4 small 12v tubes.. I think i would have searched for bargins.. But if ya have the cash it was a decent dealMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Yeah, sort of high on the price, - just pray they aren't microphonic. That's a $50 tube in 'my' mind. I've got literally a boxfull of NOS Amperex gold pin - every single one rings like a churchbell. SERIOUS issues with the gold pins for some reason - I'm talking just touching the volume control or front panel of the preamp and it's tubular bells. Hopefully, you'll luck out.
They've got a great top end, I think the JAN still has better bass control. I still roll some in from time to time, until they start to annoy me.
FYI, it's 6.3 volts on the heater, up to 130 volts on the plate - typically run around 24 volts for a line stage.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
RuSsMaN wrote:Yeah, sort of high on the price, - just pray they aren't microphonic. That's a $50 tube in 'my' mind. I've got literally a boxfull of NOS Amperex gold pin - every single one rings like a churchbell. SERIOUS issues with the gold pins for some reason - I'm talking just touching the volume control or front panel of the preamp and it's tubular bells. Hopefully, you'll luck out.
FYI, it's 6.3 volts on the heater, up to 130 volts on the plate - typically run around 24 volts for a line stage.Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers. -
I thought it said $260, not $360.
90 day warranty, you should be fine.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
WW,
Congrats on the new tubes. The Ampex 7308 are my favorite. Brought my pre amp to a whole new level. I hope you enjoy them as much as we do.
Maurice -
i just installed the Quad of Amperex 7308s and no sign of any ringing whatsoever. Bruce Wenger of BWS consulting who i purchased them from said to let them burn in for a day or so and then i should hear them at thier best. the bass is alot more focused and i can hear a definite improvement in clarity across the remainder of the bandwidth and if my initial impressions are this positive i should really be happy with the sound in a day or so.thanks....WCW IIIRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
Awesome, yeah, definately let them burn in - but if you are liking them already, it's only going to get even better.
Cheers,
Good for you WCW, N-joy! I've got a pair in my Ah! CDP with about 40 hours and they really opened up the mids and highs.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
