squeeze?
Systems
WILL THE POLK AUDIO/MOMO COMPONENT SPEAKERS FIT,IN MY 89 HONDA CRXs STOCK OPENING IN THE DOORS AND REAR AREA?
AND WHA AMP MANUFACTURERS DO YOU RECOMEND ?
Testing
Testing
Testing
Testing
Testing
For this application you want to audition our MM455's. The MM465's would require a custom mount to get them to fit in this location. The 455's on the other hand will only require you cutting off the back of the black mounting bracket to accommodate the additional depth require for these drivers. Place the bracket into a vise and simply cut the entire "drip guard" off of the back of the
mounting ring. Mount the crossover on the back of the door panel
if possible or install them inside the vehicle under the dash. Waht ever you do don't install them inside the door where water can
damge them. Water damaged crossovers are not covered under warranty.
For the rear you can install the MM465's by attaching them to the rear of the metal brackets. Just make sure to confirm the mounting depth before proceeding. You can also duplicate the rear mounting brackets by using ABS plastic or a marine grade of plywood. Just make sure to get a good seal around the drivers.
Happy Installing!!
Kim, Polk AudioTesting
Testing
Testing
