rt3
edited November 2005 in Speakers
is rt3 the same as rti4? can they be used together as rears?
Post edited by fshan on
Welcome!
    I have 2 rt10 in front and a cs250 . I have a pair of rt3 in back. i need a match for the rt3 for a center speaker so my system will become 6.1 will a rt5 or a rt7 work? or cs225? I can buy one of these. will it sound good? please help me find a good rear center. thank you very much.
    The CS225, RT3, or RT5 would be fine. The RT7 has the trilaminate dome tweeter, so it will sound different than the speakers you have. The RTi4 would be my last choice, however it would be suitable. The RT series you have use soft dome tweeters. The RTi series has silk dome tweeters if I remember correctly.
    Tschüss
    Zach
    .so the rt5 would work as the center rear for my system? i only have 3 hours to buy them so please let me know. i have an old system and need a rear center cheap I can get on auction. I could use the 2 rt5 on the rear and the two rt3 on the center of a 7.1 in the future?
    you guys know and i dont so i will trust your expertise. please let me know quickly as the auction is almost over.
Welcome!
Welcome!
