IR Remote
hexumjunkie
hexumjunkie Posts: 191
I have the H/k AVR 635 it came with a second remote for multi zone i have the multizone hooked up an works fine but i want a ir sensor outside for that remote to control the volume......what kind of cable can i buy for a 75 to 50 foot ir run and what kind of ir wall plate will work?
  • BrentMcGhee
    BrentMcGhee Posts: 548
    edited November 2005
    a simple piece of cat-5 to either a niles or an elan wall plate would be the easiest way to do it. I am unsure of model numbers for the wall plates but that is easy enough to get from their site.
