Polkmomo Amps
cam5860
I have a quick question about the momo amps. Okay they say you can remove those end caps on the amps. I was wondering how wide those caps are so I would know how much space i could save by removing them. They look to be about a 1/4 inch thick but im not sure. If i can keep the width of the amp at 11 1/2 inch's I can fit them in my truck space is really tight. I know i can fit a polkmomo mono amp in there because it is only 11 inch's wide with the end caps. But i was looking at the 2 channel to run my mids and it is 13 wide. So i need to save some space on that 2 channel amp. I figure by removing the end caps the most room i will be able to save is a half inch. Which will put the width of that 2 channel at 12 1/2 inch's.
Post edited by cam5860 on
yeah, the endcaps are about a quarter-inch wide each, maybe a little more, perhaps 3/8"...It's not good, very fundamentally simply not good. - geolemon
