No sound from kenwood vr-4900 receiver
scubamike
When I got home from work yesterday my receiver had no sound. My nefew was watching tv in surround and said it was real loud and then he heard a pop and the sound quit. Any suggestions? Is there an internal fuse or anything else that I should check?
Post edited by scubamike on
Mike,
Not really familiar with Kenwood. Unplug the unit, pop the hood, dont grab the capacitors, if there is no fuse on the back then maybe inside, however, the little guy might of fried something, if I remember right it was going into protect mode. Take a look for obvious burn/melting on the board. If something is there it should just pop out to you, if not, well, lets just say its not a good thing. Is it still under warranty, if so, I would not go inside, just call Kenwood.
RT1 -
mabye it overheated and went into protection or maby a voice coil melted together and made it short out ? cant that even happen ?
could it be the power supply?ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
any look????ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
Finally working again. I unplugged my whole system for a while and after I plugged everything back in it started working again. It must have reset itself.
Good deal, btw, that amp we were talking about is gone. I really think you may need to get an amp with the RTi150's. The Kenwood seems to be heating up, its bad for it and the speakers.
RT1
