Dilemma - RTi vs. LSi
I have two choices in the setup, both used with HSU sub VTF-3 MK2 and Pioneer 72TXV receiver.
1) Fronts - LSi 15
Center - LSiC
Surround - LSiFx
2) Fronts - RTi12
Center - CSi5
Surround - FXi5
Guys, I would appreciate any input. I'm torn between these two setups.
Thanks.
1) Fronts - LSi 15
Center - LSiC
Surround - LSiFx
2) Fronts - RTi12
Center - CSi5
Surround - FXi5
Thanks.
Post edited by falcon on
music or ht?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Probably 70-80% HT.
RTi* probally
Unless you spend that over 30-20% critically listening to music, then LSi- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If you are going to stay with that AVR, I would go RTi (and rethink the 12's or get at least a 2 channel amp) If you don't mind stepping up to a 5 channel amp, go LSi and don't look back. Then again - I am biased for the LSi (with good amplification)
Well, the sales guy wanted me to upgrade to LSi series. He told me that the receiver would handle them fine.
So, my avr is not adequate to drive RTi12?
Are LSi as good for HT as RTi12?
Also, what are some good amps, moderately priced. Can't spend 5k.
Thank you. -
Well, your receiver will really be walking the razor's edge wit the LSi15's, since they are 4 ohms AND equipped with a 8" woofer. You really need a good amp (external or areally beefy one in a receiver) to take advantage of the LSi's. I would questioin that sales guy's recommendation. The LSi's are terrific for HT, but they need substantial power. If you want to look into some affordable amps, Outlaw Audio is a good place to start.Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
+1 What he said!!!!Whadyasay wrote:Well, your receiver will really be walking the razor's edge wit the LSi15's, since they are 4 ohms AND equipped with a 8" woofer. You really need a good amp (external or areally beefy one in a receiver) to take advantage of the LSi's. I would questioin that sales guy's recommendation. The LSi's are terrific for HT, but they need substantial power. If you want to look into some affordable amps, Outlaw Audio is a good place to start.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
falcon wrote:Well, the sales guy wanted me to upgrade to LSi series. He told me that the receiver would handle them fine.
Thank you.
I really like my LSi's for music and HT. (I am about 90% or so HT) It is a personal preference though. You might like the experience better with the RTi line I can't make that decision for you. I think the LSi's are more accurate (making them a better music speaker) but the RTi's are designed with HT in mind. Listen to both and decide. Either way you will have people agreeing with you.
For amplification - do you mind purchasing used? If you must have new outlaw has a number of good amps for not alot of money. I have seen NAD for decent prices before as well. If you are willing to purchase used, you can go with near anything and could run at least your front 3 channels off separate amplification for about $500 or 5-7 channels for about $1000.
Anyway - I am sure you will be happy with whatever you decide on. It sounds like you are setting up a great system.
Almost everyone (myself included) feel the lsi's are superior with music. I don't see why this superiority would not extend outward. I have owned many rti's ... 25, 38, 10's.. I now own the lsi-9's and the one difference I noticed out of the box was the high end being more detailed and realistic with the lsi's, they are really nice with vocals and percussion.The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince. -
I own both...LSi in a heartbeat (music or HT). You will probably want that amp though.
I agree with fireshoes. Lsi are amazing at HT.
I have both, and LSi are much better than the rti, however the lsi are much harder to properly power. The LSi speakers average about 4 ohms of impedance and can dip down to 2 ohms. This means to properly power em you need a good amp that can put out enought power down to 2 ohms. I was not impressed with my oulaw amp. Some amps that i am looking into are krell showcase, krell 3250, and sunfire theater grand. I am also experimenting with car audio amps for my 4 ohm lsi speakers. I bought a rockford fosgate from crutchfield and it is in the mail. Car amps are cheaper, are specificly designed for 4 ohms load, and put out LOTS of current. Ill post something when i get it integrated with the rest of my home audio system.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
sickicw wrote:I was not impressed with my oulaw amp. Some amps that i am looking into are krell showcase, krell 3250, and sunfire theater grand.
falcon wrote:1) Fronts - LSi 15
