Speaker Setup(7.1)?? What do you guys think??
MikeC78
MikeC78 Posts: 2,315
edited November 2005 in Speakers
Hello Club Polk!!
I'm new here and would like your opinions on this setup(7.1)? Currently have The RTi8's as my mains up front with a Csi5 ceter, and would like to use the RM7300's as my rears and satellites. The 7300's will be mounted on the cealing in the living room. The cealing is approximately 8 ft. high, curious if my surrounds and rears are going to be faint as they are mounted so high? Also... is there going to be a matching problem(compromise) with the different speakers used as my rears and satellites? Trying to go with the on-wall mount speakers due to kids. I appreciate all the help!
Mike
Pioneer Elite VSX-74TXVI Receiver
SVS PB12-Ultra Sub
  • BIZILL
    BIZILL Posts: 5,432
    with proper amplification and calibration.....you'd be fine.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • okiepolkie
    okiepolkie Posts: 2,258
    Setup looks fine to me. If your system is calibrated right, you should have a well balanced system. I'm not very familiar with Pioneer receivers, but can you set individual crossover points in the receiver? If you can, set the fronts to a lower crossover point(40-60 Hz) and the rears to a higher one(maybe 100 Hz).
    Do you have a calibration disc and a sound level meter to calibrate everything?
    BTW, welcome to the forum. You have a nice setup. Enjoy it.
    Zach
    Tschüss
    Zach
  • MikeC78
    Thanks for such a fast response!! I'm just also worried that the rears and satellites don't match my fronts? Is there ever a problem with speaker matching?? Thanks guys...
    Mike
  • BIZILL
    BIZILL Posts: 5,432
    depends. give her a try and listen for yourself. if you feel the need to do more rti upgrading, then do so.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • mldennison
    mldennison Posts: 307
    looks like they both use pretty much the same drivers so i dont see a problem with that.
    you have the makings of a very nice system...let us know how it sounds when you have it all set up!
  • okiepolkie
    There can be problems sometimes, but with your particular setup, they should blend reasonably well. If I remember right, those RM speakers have softdome tweeters, similar to the RTi series.
    Also, rear speakers don't make that much of a difference since they are primarily for amibient sounds anyway.
    edit: I keep writing as other people are posting. At least we have most of the same thoughts.
    Tschüss
    Zach
  • MikeC78
    BIZILL-
    I'm purchasing the rears and surrounds due to on-wall placement. The only concern for me is the 7300's cost me more than both the fronts and center! Ouch!!
  • MikeC78
    Thanks guys!!! That what I wanted to hear from you Polk experts!! Thanks again...
    Mike
