Harmony Remote...not even here yet and pissing me off
steveinaz
steveinaz Posts: 19,545
edited November 2005 in Electronics
This Harmony remote software is doing all kinds of funky **** to my computer. Can't de-install it, can't shut it down or remove it from the systray without it reseting my computer...arrrgghhhhhhh.
Anybody else having this problem? I HATE buggy software, there may be a Harmony remote NIB on the Flea Market, still sealed if Logitech can't iron this crap out. Cheap, by the way. :mad:
Post edited by steveinaz on
  • PolkThug
    PolkThug Posts: 7,532
    I dunno. Haven't had any problems with mine, although I think I went into the registry and made it so it doesn't start at boot up.
  • steveinaz
    When I try to uninstall it in Control Panel (Add/remove software), as soon as I click "remove" my system resets. Log back in, and there it is, still on the system. I've run thru Task Manager and I don't see it listed as running in the background....
    it acts like a damn virus....errrrrrrrrrrr
  • Ricardo
    Ricardo Posts: 10,636
    Never had any issue; I do have the monitor icon permanently on, but it does not bother me.
    SOPA
  • okiepolkie
    okiepolkie Posts: 2,258
    I haven't had any problems with mine. I've got it where it doesn't begin at startup, so it doesn't seem to affect my computer at all. I haven't tried to uninstall. Give Harmony a call or email. They have decent customer support, so they should be able to walk you through it.
    Zach
    Tschüss
    Zach
  • PolkThug
    Did you by chance try to uninstall it a different way before trying the Add/Rem program feature?
    Maybe step through the motions of "installing" it again, then try the Add/Rem programs.
  • Willow
    Willow Posts: 11,233
    I didn't have that problem either.
    I went into add remove followed the steps what happened I don't know but once I downloaded the new updates everything was just fine.
  • steveinaz
    No, I used Control Panel's Add/Remove;
    I'll try this tonight, reload and maybe it'll fix the glitch...
  • faster100
    faster100 Posts: 6,124
    Go into msconfig and remove it from bootup,
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • steveinaz
    It's not showing up there (surprisingly). That was my first move last night. I also don't see it on running processes in task manager either...
    When I click "remove" in CP, it starts to bring up a dialog and looks like its doing something, then the computer resets. I tried 7 or 8 times last night, everytime it would force a reboot right in the middle of doing its thing...very strange.
    I'm a computer tech with 15 years experience, but this one is pushing my buttons. I ran Reg Mechanic, ran Spybot S&D and Adaware (there are rumors that logitech software lays down some pretty hideous spyware). Nothing, all 3 programs came back with nada problems.
  • Willow
    I would ask you give it some time you will not be disapointed. Not sure if they can help, but they are supposed to have amazing CS. You may wish to give em a call.
  • steveinaz
    I'll get it figured out, it's a mission now....
  • okiepolkie
    This would be my next step as well, even before I talked to customer service.
    I don't have my laptop right in front of me with the software installed, so I can't help anymore right now.
    What version of Windows are you using right now?
    Tschüss
    Zach
  • steveinaz
    Yep, thats what I'll do tonight. Try fully installing again then removing...
    XP Home
    Athlon 1.8Ghz AMD
    Asus socket "A" MB
    1Gbyte RAM
    Nvidia Gforce 256Mb AGP Video (Asus)
    No Anti-virus s/w
    Nothing running in the background
    79% HDD available (60GB)
    Built the system myself, it's rock-solid (about 2 years old)
  • louhamilton
    louhamilton Posts: 209
    I just removed the software from my media server PC this past weekend. I was cleaning up all software and processes that weren't needed on that particular box. It was removed without issue. Even did a reboot to confirm. Nothing. There is no trace of it.
    Try the re-install/uninstall method. You may have something missing. Did you exit the process first? This soometimes causes things to not uninstall.
    -Lou
  • steveinaz
    I exited the systray icon, then went to Add/Remove. Actually, the first time I tried to hit "exit" on the systray icon, it made my system shutdown; when I went back in and did it a 2nd time, it exited without incident. I then removed the shortcut from the "Start up" folder, rebooted and tried to remove. That's when the problems started...
    I wanted to remove it and do a fresh install to because of the strange behavior with the systray icon---well, now it shuts the system down (actually reboots) everytime I try ti uninstall it.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Steve,
    Have you looked at the installed software directories and files in a Command Prompt (DOS box)? I do my best slash and burn in DOS. ;)
  • steveinaz
    Yep, I'm a DOS-hound too. Shows everything there that was initially loaded in the ~program files\Logitech\Harmony Remote\*.* area. I thought about manually deleting, but then you end up with orphaned registry entries and files all over system32 and win directories...I'm anal.
    I think top-loading and re-trying it will probably fix it, we'll see what happens tonight.
    Just thought some here may have experienced this (there's cases on the net) and maybe knew a quick fix, you know---being lazy in other words.... ;)
    FWIW, there are some issues with this sw and some ATI graphic cards when set to full hardware acceleration setting...just an FYI.
  • BIZILL
    BIZILL Posts: 5,432
    i'm not afraid of system registry. i'd go in and manually delete anything to do with harmony as well as the rest of the hard drive. then restart computer and try installing again....this comes with the typical warning, of course: back up your registry first. i never do, though.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • PolkThug
    If that doesn't work, we can easily kill it in the registry so it won't fire up on its own, keep us posted.
  • PolkThug
    In the registry, go to:
    HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVersion/
    and look for references to it in:
    Run
    RunOnce
    RunOnceEx
    and delete them.
  • BIZILL
    BIZILL Posts: 5,432
    or just use the find and find next feature to search while in your registry, just in case it may have posted its trail anywhere else.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • steveinaz
    Registry hacks and manual deletion will be my last step. You still have the potential to leave behind a ton of orphaned files when you don't use the programs uninstall routine, thats what I'm trying to avoid. I'm pretty sure reloading wiill probably fix the problem...I'll keep you posted...
  • steveinaz
    Well, got up this morning and thought I'd make on last attempt at uninstalling before doing the reload/uninstall routine.....it worked!
    I'll do a "fresh" load when the remote arrives...
  • Ricardo
    Glad to see you got that out of the way....you'll enjoy that remote :)
    SOPA
  • okiepolkie
    Glad to see it worked. Hopefully the remote itself won't give you any problems.
    Tschüss
    Zach
  • steveinaz
    I think it was because the computer kept "warm" booting; I don't think I did a cold boot and shut it down completely---some glitch was probably residing in memory or a registry re-read wasn't occuring.
  • jafdc
    jafdc Posts: 8
    I've had trouble too on our Windows XP machine. But it seems to work fine on my father's Macintosh.
