Speaker Set-up...
fab5valentine
Hello Everyone!
As seen in the pic, there lies my delima.. This room is not too big on it's own (18X22) but from where the pic is taken there is a good size nook and a big kitchen to the rear of that. That's a lot air to move, plus the ledge over the cabinets to a Den. This is a pic when it was on the market so nothing there is mine except the room itself. I have filled the whole with a TV from top to bottom.. I wish I could put some small sat speakers just like he has set-up to take care of me needs but as I stated in my past posts, I've out grown my RM6600 system.
The reviews on the RTi28 are good and many folks here seem to like them for a small speaker, but will they drive the space? I'm pretty sure that If I can find RTi38's in good cond I will go with those as fronts, maybe RTi6's, and probably set them on the ledge with the CSi30 (I may have next week).
My surrounds I'm not sure.. There's another window to the left so wall mounting doesn't look to good, and there's no R-side viwing wall for fxi's (it's open), so I guess I'll mount some small RTi's or go in ceiling TCi60's or 80's.
Sub.. I have a PSW350 (I like it), but I think I'll need to go bigger to move some air.. How does the PSW650 rate with the Velodyne DPS12??
Any set-up recomendations? There is no existing wiring for the center on the ledge or the fronts to go there too, but that shouldn't be a problem. It's how to get out of that cabinet (clean), and run that long cable connection to the corner..
Thanks for advice ealier on speaker selection questions. I was offered a RT35i and RT25 to run with my new CSi30 (to be).. I think I'm going to stick with the RTi38 or RTi6's and maybe go RTi28's (mount to ceiling) as surronds, maybe RTi4's or in ceiling as stated above.. I'd still like to have 28's all over or smaller, but like I stated I have to drive a lot of air.. Let me know if I provided enough info.. Oh, I'm using a Denon 2802. to drive em..
Here's the pic., I hope it says a 1000 words.. THANK YOU!
fab5valentine
fab5valentine
-fab5
Klipsch RB81's/RC62/RS52's
SVS PB12+/2
Denon 3808CI
Panasonic BD60
Toshiba 56MX195 1080p
SVS PB12+/2
Denon 3808CI
Panasonic BD60
where do people keep coming up with RTi28's and RT35i's. those have been out of circulation for number of years if i'm right.
Look towards the RTi6's instead... get four of those.. for fronts and surrounds, a matching center, and a big subwoofer. your system will rock hard with that set up.
or if cash isn't a problem. go with LSi9's all around and LSi center and a big ol SVS subwoofer.PolkFest 2012, who's going>?
