bass management
gright
gright Posts: 22
My system fronts LSi15's, center LSiC, rear full size cerwin vegas, and I have an SVS PC-Ultra on the way via UPS tomorrow. I have a Denon 3806 receiver that does allow you to set speakers to large or small individually and you can set different cross over points for each speaker. What settings should I use in my receiver including large or small for each speaker and then what crossover settings for the one's that are selected as small? Ofcourse if I select a speaker as large then I can not select a cross over point.
Help clean up the city, eat a pigeon.
Post edited by gright on
  • aaharvel
    aaharvel Posts: 4,489
    edited November 2005
    I suggest small for all speakers and 40hz for the lsi15's~ and whatever you feel sounds best with the rest of the speakers.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • gright
    gright Posts: 22
    I notice that the specs on the LSi15 include a "lower -3db limit of 30hz". What is the lower -3db limit and should the crossover generally be set about 10hz above this? Hence for my LSiC the limit is 52, so I should set the crossover at around 60?
  • PolkThug
    PolkThug Posts: 7,532
    Sounds like a good plan to me.
  • wingnut4772
    wingnut4772 Posts: 7,519
    I have my 15s crossed at 60 and they sound excellent.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
