Recommended Mounts for RM 7200?
benochs
benochs Posts: 2
edited April 2002 in Technical/Setup
I would appreciate any input on recommending mounts for the RM7200 series? I just bought the speaker system and am looking for suggestions on which mounts to choose? Is their a brand out there that works well and is cost effective?
I would like to be able to rotate and move the speakers with the mounts..
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2002
    Look up, above the post...
    See 'Club Shopping', click it, goto stands and brackets.....
    That's one option at least, Polk recommends them....
    Cheers,
    Russ
