Help Kim!
WhoopdieShiit
i was wondering if there was any way to get more out of my polk dx ten inch subs. what should i have the crossover set at frequencey wise? and how much power should i be able to feed them after they have been broken in? thanks
Brandon
Brandon
Post edited by WhoopdieShiit on
Brandon,
If you goal is to obtain "MO - Bass" from your dx10's then build a
Iso - push pull bandpass enclosure for these subs. If you want the design plans call us at 800-377-7655 and I will be glad to fax them over. This box has "gain" incorporated into the design so you won't have to play them hard to get a lot of bass from these woofers.
Bass On!!
Kim, Polk AudioTesting
Testing
Testing -
I got the same box setup for my 2-dx12's. Lets just say polk should invest into hearing aids....
