Wiring Speakers to 2 ohms
astragsiii
Wire a pair of 4 ohm voice coils in parallel to a single amp channel.polkaudio sound quality competitor since 2005
generally, it's a bad idea unless you're doing it with subs...It's not good, very fundamentally simply not good. - geolemon
would it be ok if you were to run midranges in series, I would assume that the amp would have the gain set higher to compensate, but with that added resistance, would it be less likely to clip?Picking ones nose signifies a strong sense of self discovery
System in the works:
PP 6V6 with 12ax7 pre ~ 20 watts
15" Jensen MOD 8ohm ~ 97db SPL
DiMarzio HS3 and/or Tone Zone S -
i know the guy whi i got all the stuff off had it all running at 2 ohms
well, running mids in parallel decreases the load on the amp, dropping its damping factor, tripling its distortion, and making it run much harder - all bad for sound quality... running mids in series does all that stuff the other way, which is good for the amp (as long as it can still cleanly make the power you need it to make), but there's a phenomenon called back-EMF that makes it a bad idea to wire speakers in parallel (basically, if one moves, the other tries to move to counteract it - so you have the speakers fighting both each other and the amp, and that can't be good)... if i had to choose, i'd do em in series...It's not good, very fundamentally simply not good. - geolemon
"called back-EMF that makes it a bad idea to wire speakers in parallel"
so, series is good? lol I think I know why people have a hard time understanding me, I write one thing which reminds me of something else, and the logical order goes "POOF"
OK OK I'm new to the whole series / parallel so could some one please enlighen me
Ok, series is basically running both speakers on the same circuit. Look at the Picture i attached, now its only using one channel of the amp. Now wiring this way increases the ohms simply because you are making the signal go through both speakers one after the other. It basically adds the two ratings of the speakers. 4ohm+4ohm=8ohm
http://www.polkaudio.com/forums/attachment.php?attachmentid=12266&stc=1
For parallel, its using one channel of the amp as well, but each speaker is using its own "circuit" Wiring this way decreases the ohms because now the signal has two places to go, cutting the resistance in half. Two 4 ohm speakers, in parallel, has a 2 ohm load simply because the signal is "split" between the two.
http://www.polkaudio.com/forums/attachment.php?attachmentid=12267&stc=1
parallel.bmpPicking ones nose signifies a strong sense of self discovery
So can i do the with my 6x9's then in parrallel
hellohello wrote:"called back-EMF that makes it a bad idea to wire speakers in parallel"
so, series is good? lol I think I know why people have a hard time understanding me, I write one thing which reminds me of something else, and the logical order goes "POOF"It's not good, very fundamentally simply not good. - geolemon
