SRT vs RT5000 opinions?
dpowell
dpowell Posts: 3,068
edited November 2005 in Speakers
I'm posting this thread because of the SRT system that is currently being auctioned on ebay. Like many on this forum, I've drooled over the SRTs for quite awhile but I've never heard a set and often wondered what the reasons would be to put in the effort to grab a set.
I'm asking out of ignorance here and honestly want to know from those who've had the pleasure of listening to the SRTs. Can those of you who have heard a set of them compare them with the RT3000's or current Polk speakers? What kind of amp does a person need to drive them? I'm asking because I live just a few hours from Vegas where they're located......
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
Post edited by dpowell on
  • TroyD
    TroyD Posts: 13,085
    The SRT's in a completely different league. Completely
    BDBania
  • beardog03
    beardog03 Posts: 5,550
    well....
    that explains it..!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • dpowell
    BDBania
    Care to expand.....?
  • danger boy
    danger boy Posts: 15,722
    RT5000 ? have never heard of those before. RT1000, RT2000, RT3000 yes. RT5000 nope. educate me on these somone, if they exist.
    PolkFest 2012, who's going>?
  • dpowell
    RT5000 is the complete set of RT3000s, CS1000 and FX1000's.
  • TroyD
    TroyD Posts: 13,085
    I dunno what to say, really, the SRT is probably the most impressive thing I've ever heard. It defines effortless sound. The RT5000 is cool, no doubt, but it's not SDA.
    BDT
    F1nut Posts: 50,735
    What he said, it's not SDA.
  • tntvt
    tntvt Posts: 121
    I have both, I have not once set up the 5000p system after getting the SRT's. The SRT's are amazing I love them so much I bought a second set!! If you have questions feel free to pm me. For now don't waste time just go get them!
  • ND13
    ND13 Posts: 7,601
    I believe its unanimous!!
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • dpowell
    Hey TNTVT, just looked at your system showcase. How do you drive 2 X CS400 and the CS1000 center channels all at one time!? Do you have pix of your SRT system?
  • tntvt
    tntvt Posts: 121
    At the time I used my preouts with a amp. I am now in a new house with a new system. I have wanted to post a family photo of all the speakers. I'll try for this weekend. :)
  • dpowell
    Thanks all for the input. For now I am going to stick with my current system as I don't have the funds needed to purchase the amp upgrades needed to power the SRTs. My newborn has diverted funds away.... :rolleyes: I will just enjoy the RT5000s and add an SVS PB12-Plus/2 sub when $$ is available. That will do until I can do a set of SRTs justice.
  • bknauss
    bknauss Posts: 1,441
    I've found a sub isn't exactly necessary with the RT3000s. They go low, and that's a total of 600 watts of sub power. Only reason to get another sub is for low end extension.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • dpowell
    I assume you are refering to using the RT3000 subs for dual purpose; both stereo bass as well as the LFE channel? I found that when I used both the line level and LFE inputs on the subs that the bass seemed to be less precise and more boomy. Maybe I just had them configured improperly. I currently use the speaker level output for the top cabinet and line level output from the amp to the sub amp. I'm just looking for something to output the LFE channel cleanly and at the same time have enough power to keep up with the combined power of the two RT3000 and one cs1000 subwoofers.
  • beardog03
    stick a PC-Ultra in the corner and yer done..!!
    then put on Monsters Inc...
    have a clean pair of shorts handy....
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • bvette94
    bvette94 Posts: 356
    dpowell Hi i have the rt3000p front speakers a cs1000 center and an svs pb12plus2 sub. The extra bass you get from the svs is worth every penny. if you can get one it will be money well spent imo. i did comparisons with my system playing the movie open range. i was using a polk psw 550 sub and the rt3000s and then with the svs. i thought it couldnt get much better untill i heard it with the svs. your original question imo i think the cs1000 and the fx1000s are better center and rear surrounds than what comes with the srt system however i have not owned the srt. i feel that if you added the svs you wont want to make any more changes for some time to come.
    Bob
  • dpowell
    Bob
    Exactly what I was thinking. Even though the RT3000's hit low at 300watts, there is only so low 8" woofers can hit.
  • bknauss
    My current setup is the preamp with the sub channel shut off and high level inputs to the sub amp and then the parallel connection to the top cabinet. I've played around a little bit with a dedicated sub, but I've found it hard to sound good with the amount of adjusting available and no current measuring equipment to help out (crossover on RT3000s and the sub, gain adjustment on the RT3000s and sub).
    But as always, if it sounds good to you, go with it.
    Guess its time for me to break down and get an SPL meter :)
    Brian Knauss
