FS: Parasound D/AC 1600 HD
RuSsMaN
RuSsMaN Posts: 17,985
edited November 2005 in Flea Market
Parasound D/AC 1600 HD Digital to Analog Converter with HDCD decoding.
1996 - 2001 $1500 MSRP
DAC-1600HD Digital to Analog Converter. The DAC-1600HD comes with the revolutionary HDCD (High Definition Compatible Digital) process decoder. It gives your music incomparable detail, which is the difference between simply hearing music and becoming a part of the performance. True balanced digital dual differential configuration make it a rare D-A treasure.Low jitter Crystal CS8412 digital receiver, Four Burr-Brown PCM 63P-K DACs, Three separate power transformers, Four digital inputs: AES/EBU, ST, TOSlink, Coax, Outputs: Balanced, unbalanced analog, Digital recording output jack, Polarity invert switch.
Frequency Response 2 Hz - 20 kHz, 10.25 dB
Signal to Noise Ratio > 108 dB, 113 dB typical
Channel Separation > 100 dB @ I kHz
Total Harmonic Distortion < 0.0015% @ I kHz
Amplitude Linearity >100 dB; 102 dB typical
Phase Linearity +/- 0 @ 20 kHz
Maximum Jitter (HF) < 50 picoseconds RMS, using selected low jitter Crystal 8412 Digital Interface Receiver
D-A Converters Four Burr-Brown PCM 63P-K (highest grade) 20 bit, push-pull for each channel and fully balanced digital operation
Oversampling Rate 8 X (352.8-kHz)
Digital Input 32 kHz, 4.1 kHz, 48 kHz; Consumer standard SPDIF
Digital Filters PMD- 100 High Definition Compatable Digital, Digital Process Decoder
Absolute Polarity 0 or 180 degree switchable
Digital Inputs Coaxial: 75 ohms RCA TOSlink fiber optic: EIAJ Standard CP-340/RC-5720, 660 nm typical wavelength ST module fiber optic: AT&T Standard, 820 nm typical wavelength AES/EBU Balanced XLR
Outputs Balanced Analog Line Out: 6.0 V nominal, 1.2k ohms
Unbalanced Analog Line Out: 3.0 V nominal, 600 ohms
Digital: 750 RCA coaxial, 0.5 V peak-to-peak
Power Supplies 3 separate transformers and nine regulators for digital circuits and for each analog channel
Power Requirement 120 V, 60 Hz, 18W; may be re-wired for 220-240 V, 50 Hz
Dimensions 19" W x 3" H (3-5/8 with feet) x 13-1/8" D
Net Weight 13.5 lb.
$295 shipped to your door. Tara Labs Prism 200d 1m Digital Coax included ($90 cable in retail packaging) to get you started. Pics to follow later this evening.
Post edited by RuSsMaN on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Nice DAC, I have one in this lineup, when I hooked a POS shuffle player to it, the improvement was quite noticeable, really smoothed things out, the Polk XM tuner sounds great too.
    For this price a no brainer.
    RT1
  • danger boy
    danger boy Posts: 15,722
    anyone looking to get into the world of external DAC's, this would be a great place to start.
    PolkFest 2012, who's going>?
  • RuSsMaN
    Hell Al, it would be a great place to finish! ;)
  • TroyD
    TroyD Posts: 13,124
    Yup, unless you plan on spending a lot of wampum, this could well be the only DAC you ever need.
    BDT
  • Shizelbs
    Shizelbs Posts: 7,433
    Sold to me.
    Russ, PM on how you want payment and all that other BS.
  • danger boy
    nice..... is this your first venture into DAC country? lemme know what you think. I'm sure you'll enjoy the sound it brings out of your CD's. :)
  • Shizelbs
    Yes, this is some virgin DAC territory. The results will likely be mixed with the effects of new rooms from a new house.
    yes you heard me..
    NEW HOUSE
  • reeltrouble1
    Very nice grab. I paid way way more for mine, of course I did not get from the all time deals leader at CP.
  • audiobliss
    audiobliss Posts: 12,518
    Nice grab. And, congrats on the house!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • rskarvan
    rskarvan Posts: 2,374
    Its interesting to compare the specs of the Parasound DAC to my Adcom DAC. My Adcom 700 DAC sounds terriffic. And, the Parasound's specs are superior to the Adcom's. Interesting.
  • Normanality
    Normanality Posts: 297
    Outstanding deal!
    I absolutely love my Parasound D/AC 2000 Ultra.
    Never knew what I was missing.
    heiney9 Posts: 25,517
    I know from experience both are EXCELLENT sounding units. Don't let the specs fool you. Specs aren't everything when it comes to audio. Certainly a guide-line but nothing more. Not saying which is better but the Adcom is no slouch even by todays standards.
