Placement of Rear Speakers
beavis814
beavis814 Posts: 10
edited November 2005 in Speakers
I am currently finishing my basement, and the area I have planned for the home theater is approximately 13' x 17'. I am currenly wiring the basement for surround sound, and I will be placing a pair of FXi5's that I have on one of the 13' walls. I am looking for opinions on how far these speakers shoud be spaced from one another. I am thinking about 8' apart, or would I be better placing them about 6' apart?
Thanks in advance for your help!
Post edited by beavis814 on
  • Emlyn
    Emlyn Posts: 4,687
    Are they going to be the only surround speakers in a 5.1 system? It may make a placement difference if you will also have side surround speakers in a 7.1 system. If it's just 5.1, I'd say space them 3 feet from each side wall (measured to the center of each speaker), meaning 7 feet apart. They would be set to bipole rather than dipole as rear surrounds. If they are in a 7.1 system, they should be closer together, maybe 5-6 feet apart.
  • mldennison
    mldennison Posts: 307
    i assume since you are talking about spacing apart from one another that the 13' wall is behind the seating area. with your wide room that seems to be a good choice. in that case, how wide is your seating area? i would think you would want them as wide as possible jsut due to your room size.
  • Eric W
    Eric W Posts: 556
    5.1 or 7.1?
    Anyway, here is a pretty good recommendation on both 5.1 and 7.1 surround placement:
    http://www.dolby.com/consumer/home_entertainment/roomlayout.html
    I would base the width of the speakers depending on your distance from the rear wall.
    -Eric
    -Polk Audio
