my speakers and TV distortion
pmckeealaska
pmckeealaska Posts: 808
edited November 2005 in Speakers
I own a pair of LSi25's and I have noticed that there are some lines on the side of the TV screen while watching movies. Not really noticable, except when the colors are dark. Its kind of like zebra stripes in the top corners. I thought these speakers were magnetically shielded? I cant really move my speakers any farther from the TV due to space constraints. Will this harm the speakers or the TV? I can live with it for now, since its pretty subtle.
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
  • Eric W
    Eric W Posts: 556
    Yes you are right the LSi25's are magnetically shielded, however there is no such thing as a 100% magnetically sheilded speaker. The very operating principal of a speaker relys on a magnetic field for it to function, so there will always be some leakage. This is particularly true of the woofer section. That is most likely the cause. It already has a reverse polarity magnet on it. Some TV's are more sensitive than others to magnetism. It is not recommended that the TV be kept in this state if there is noticeable visual distortion, subtle or not. Unfortunately, short of using another TV, distance is the only cure here.
    -Eric
    -Polk Audio
  • pmckeealaska
    Thanks for the info Eric. Its kind of a cheap TV, so I'm not too concerned about it as long as the speakers wont be affected. I'll be moving into a larger place this spring and will space the speakers farther away from the TV then.
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
  • drew spelts
    drew spelts Posts: 310
    this could also be an effect called combing i believe. if you take the speakers away for a minute and it still persists then it is most likely this effect. The effect is directly related to certain DVD players. just my 2 cents. After all every little bit helps.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
  • steveinaz
    steveinaz Posts: 19,547
    +1 on Drews comments. It's not the lsi's.
  • pmckeealaska
    Hmmmmm.......I have a Denon DVD 2900. Not sure if this model causes the effect you have mentioned. I always thought it was an artifact of the TV not being that great....no prgressive scan capabilities for instance.
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
