Rear Surround...RTi8's or RTi6's
drew spelts
I am building an all new home theater system that will be using a harman kardon AVR 635 and will probably be using RTi12's up front with a CSi5 center and wanted to know what you polk guys recomend for rear surrounds. The options are the RTi8's or RTi6's I have very nice pedistal stands that I made myself if I decide to go with the 6's so there will be no extra cost. i will be using this 75% or more for movies. It will be a 5.1 setup of course. Kinda thinking the 8's will sit about 6 inches too low because of high walls on the couch and I need the sound up near the ears. I do not want to lift a tower speaker off the ground because it would look stupid and might effect sound quility out of lower port. Please let me know your expert opinions. my room is only 15 X 15. and the rears will be ablut 2 feet from my head lol. because I can not get them back against the wall any farther.
Thanks, Drew
Thanks, Drew
Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes:
RTi10's Up Front
CSi5 Center
Well ideally the best is 5 matches speakers but of course it's hard to get a tower center or what not and well yes if you don't like towers llifted than well just go with the bookshelves especially if you want to use your stands.
Most of the time surround effects don't get as much info/strain/ and bass that is required of the front sound stage so it's not AS important.
I would say save your money and show off your stands get the bookshelves.
or if they are really close get dipole/bipole
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
I have the RTi6s as surrounds and love them! They match the CSi5 perfectly.
CarlCarl -
oh yes Welcome!
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Welcome to the forum.
I have RTi6's matched with a CSi5, RTi38's & RTi100's. I like the RTi6's, very good speaker for the price.Michael
NORTH of 60° -
RTi6's, primarily because they can be hung on the wall alot easier then the RTi8's. Surround speakers ideally should be approximately 6 feet off the ground the best surround effect, rather then on the floor.-Eric
-Polk Audio -
Just bought a pair of RTi6's this morning. They were on the Bay for $200 buy it now. SO I snatched them UP! Tell me if you think thats a good deal seems to ba a little more than half price. BTW, They are guaranteed to be as pristine and perfect as possible. Makes me happyHarman Kardon AVR635
RTi10's Up Front
CSi5 Center
Furman RA-1210:rolleyes: -
Is it worth it for me to upgrade from my RTi4's to RTi6's for my surrounds? It will cost me $140+tax to do so.Panasonic 50" Plasma + Pioneer 6010
Toshiba XA2 HD-DVD
Panasonic BD30 Blu-Ray
Pioneer 1014
Polk RTi12 (front)...Polk CSi5 (center)
Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
3 Outlaw M-200 Amps -
if you can afford to upgrade, i'd say, "why not?"
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Money isn't a problem if I would notice the difference.If there would basically be no difference then I would be wasting my money....BIZILL wrote:if you can afford to upgrade, i'd say, "why not?"Panasonic 50" Plasma + Pioneer 6010
Toshiba XA2 HD-DVD
Pioneer 1014
RTi8 - ONE HUNDRED PERCENT!
One thing, you will have to raise them off the floor till they are about 2 feet away from the ceiling - remember that.
Also, full range (tower) surrounds OWN bookshelf surrounds in every form. Just make sure you set them to LARGE to take advantage of having larger surrounds. I love full range center and surrounds.
DO IT!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
i was gonna go with rti8's for 7.1 surrounds. that way i'd have all matching speaks minus the center and the svs, but i ran out of space in my room.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
If you watch recent action movies. There is a chance you will notice a differance in some sound effects, like fly-overs, explosions, thunder.GaryZ06 wrote:Money isn't a problem if I would notice the difference.If there would basically be no difference then I would be wasting my money....Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
